Root [Boost Mobile] [ Team Osiris ][ Linaro ] CyanogenMOD 10 Beta 2.0 Camera WORKING ( Jellybean 4.1.2 ) for ZTE WARP
Is there a way to turn off speakerphone? Tapping the little icon does nothing. I've rebooted several times and wiped cache and dalvik and fixed permissions. I noticed some people saying the mic only worked in speakerphone but mine won't even turn off! It's almost worth it though just because I don't want to go back to gingerbread.
Ok so it seems that M3 broke WiFi for me completely. I've rebooted and turned on/off wifi about 50 times as well as reset my router and nothings working. I don't know if anything is changed for wifi between the first three builds but i cant get it working. Is it only me or are others having these problems too?
Perhaps it was a bad flash?
Can anyone here tell me that what actually custom rom is? And is it a modified form of the actuall Os from the company or is it totally different?
And if I need to upgrade my phone from gingerbread to jellybean, where can I find the required custom Rom and does that support multi window or not?
Anybody else having a hard getting unknown sources to stick? Every time I check the box and back out I look and it's not checked.
I'm also having a problem using WiFi. After I turn it on I reboot and it's on, however no matter what I do it won't associate.
could you guy fix the camera issue and Bluetooth issue and the Sensors issue
Welcome to Android Forums Winty! The devs know what is and isn't working with the rom. Its posted in the first post of this thread. Its really important that you read the first post thoroughly so you know what's going on before you make a comment because other members may not be as nice, and it also bothers the devs I'm sure.
Something else that you should know (this is a just in casies) don't ask for ETA's on new releases, the devs arent getting paid to do this and we should be grateful.
Remember this and you'll be fine ^_^
So people that have successfully connected WiFi, what encryption are you using? I've rebooted over and over to no avail and I can't understand how others have done it.
There was an earlier post where someone had a Linksys router and couldn't get their WiFi working. I too have a Linksys and I haven't been able to get it to work. I rebooted, cleaned cache and dalvik and all that good stuff. So the people that got it working what routers do you have and did you change any of the settings?
Ok, went back to n00b since Wi-Fi is critical but I've set nothing up yet. I'll reflash the nightly and see how it goes - I just switched my encryption to tkip only.
K so my findings were a little different. I have a subnet of .0.1, so I had to manually configure the connection with a static IP. WiFi works now though, except the signal meter.
M3 is crap. sorry guys. i did some things to the ramdisk. that have been reverted for M4.
