trenchkato
I like the new dial screen.. how it pulls up contacts as you dial.
when i selected the cm7 in cwm recovery it popped up confirm install??
no
no
no
no
no
no
yes install cm-7.1.0
no
no
no
?? why is there so many no
okay got rid of search 1.1.. havent noticed any changes..everything seems to be working okay still.
would it be okay to get rid of live wall papers?
why is the keyboard like 11 mbs? is there something special about it? lol
check the download, might have corrupted. Just redownload and copy to the sd card.hey hroark i cant install zips in cwm. i get an error saying:
finding update package...
opening update package...
E: can't open /sdcard /beta4bhf1.zip
(bad)
installation aborted.
same thing with cwm update
Also make sure you are not trying to use the update.zip menu.
You want to be opening the install from zip menu.
hmm ok, I have not done anything with either of those files so I think I will let someone else in to help with this.thats what i did. i downloaded the file and cwm update twice from computer and from my phone. i also chose what to install not hit install update.zip
(bad)
what version of cwm do you have?thats what i did. i downloaded the file and cwm update twice from computer and from my phone. i also chose what to install not hit install update.zip
try reinstalling CWM (the new fixed version)
i cant thru cwm so i tried odin, but the odin zip doesnt have a stick.zip inside
the stick.zip is for the stock rom
it deletes the file in the stock rom that restores the stock recovery on reboot
I've noticed very improved battery life
