Can't get ap2sd or s2e to work any help
Hey hroark..i would like to flash hotfix 2 ..but the problem i had was ..i got rid of the cm7 keyboard and replaced it with go keyboard. Shouldnt i convert go to a system app? So that when i do a wipe/reset and then flash hf2 when it starts up ill have a keyboard? Otherwise with go as a data app.. it would get wiped and at start up after flashing i wouldnt have keyboard
Okay...
would you agree that i should convert go to system..just incase
So I just got cm7. On my prevail and got my first call about bleeding up my speaker and I can't turn it down or at least candidates figure out how to has this happens to anyone
Maybe?So I just got cm7. On my prevail and got my first call about bleeding up my speaker (volume issue?) and I can't turn it down or at least can not figure out how to, has this happened to anyone
Sorry about that .... yea with any audio turned up it sounds real bad distorted I have messed with sound settings and can't get it to stop now my keyboard is slow and maps don't work other the that I'm liking cm7 my batteries lasts alot longer then ever before thanks for the hard work and any help you might have
there is an app called DSP manager that come with the ROM, you should be able to adjust sound with that
If you installed the update to Maps uninstall the update
I can make and adjustment to the sound driver to bring the volume down
do you guys/gals think I need to do that
I can make an adjustment to the sound driver to bring the volume down
it will be nice to have it work right out of the box for the users that dont know what's up, but i really don't mind.
both hf 1&2 install the hosts file in the wrong directory, it should be in system/etc/ correct?
