johnny424
Android Expert
ADW EX runs great with this ROM.
yeah i also noticed that..seems much snappier than the standard adw.but i thought it was just me
Yup !! I've been playing with it all morning . There are a lot of options .
I am sure that you know this already, but the CM7 zip comes with standard free ADW. ADW EX is a paid app (cheap) upgrade.
The free launcher runs just fine. But, I have noticed that EX seems to run even better. It takes ADW settings off the standard settings menu and moves it somewhere else, but EX adds a lot of nice additional options too.
I finally uninstalled the free app but you can leave both and switch between them if you like. Just be sure to move EX to system apps in case you do a wipe. Actually, I haven't done a factory reset in forever. Not with this ROM anyway.
CM7 itself has enough options to keep you entertained for quite a while.
As far as I know you can use any launcher you prefer.
so you removed original adw? i was worried about doing that so i left both..but see no need to keep both. what about the stock browser have you gotten rid of that?
Yep. I use Dolphin HD. I run Facebook, Twitter, LinkedIn, Google+, Maps, etc. from it instead of using the apps. Wish the maps app worked though.
I also installed Calengoo and uninstalled stock.
I use Handcent and uninstalled stock.
Of course, I have backups of the stock apps just in case.
If you use a lot of apps, or just want to sd-ext install S2E. I have not tried DarkTremor with CM7 but it does work. Not sure which is better, but S2E is made for Cyanogen mod.
with ct i would get rid of everything and replace it with what i wanted..but sense i tried to get rid of stock cm 7 keyboard and system converted go and it gave me all kinds of trouble for some reason..you backing up apps with tb?
I just checked the Market and the ADW EX is $3.32 . I think I'm gonna get it . I'm also running S2E , it was the first thing I installed after installing the ROM .
I'm running TB Pro and it works GREAT ! It's what I used to transfer all apps after switching from CTMOD to CM7 . I'm getting ready to try some keyboards . I'll letcha know what i find that works .![]()
I agree here, the new swype beta is way way way better then even the older swype betaI switched to Swype Beta and I love it. I still keep the stock keyboard but I never use it.
I still use Titanium Pro a lot. But I have had some minor and wierd stuff with it, but rarely. Mostly from using it to move apps from data to system or to SD. I really don't do this anymore anyway with CM7 so for most stuff TB is fine. I use Root Explorer a lot more for odd stuff.
Ok guys . I got Thumb Keyboard 4 from Amazon when it was free . It's working great plus there are a lot of nice themes and layouts to choose from . I like the looks of the split keyboard . I think I'll probably run it for a while .
@ Wyelkins , I don't use Swype that often . I just installed the VoiceSearch.apk which didn't come w/ the ROM . LOL , I get lazy and don't wanna type sometimes .![]()
EDIT: I may install Swype Beta just to give it a try .
I did the same thing and used voice for a long time. I finally took the time to really learn Swype. Now, I hardly ever turn on my laptop for much. It is all on this phone with Swype beta. It has really changed me into a smartphone USER, not just something to play with and have cheap wifi.
LOL ! OK , you talked me in to it . I'm gonna try the Swype Beta . I just bought ADW EX too . I'll end up playing with it for an hour or so . HEH , this is like having a new phone all over again .![]()
One thing I realized recently: I was sick with the flu and did not feel like doing anything including using the laptop. But I could lay in the bed with the phone and stay occupied.
or you can try my solution
http://androidforums.com/galaxy-prevail-all-things-root/483970-mod-cm7-data-ext.html
I have this problem also, it seems to be with receiving the transfer. I can bt from prevail TO anything, but from another device to prevail fails every timeUnfortunately, I have a minor error to report regarding Bluetooth functionality. It seems, I can no longer BT files back and forth between mine and my fiances prevail, she is on B4 and I am on B3 with the Speakerphone fix added but no matter which way i sent the files it wouldn't even connect and attempt to send, just instant failure.
Getting late, I'll try with stock tomorrow.
