sellersj27
I can not flash the apn fix for some reason.... It fails in twrp. No sig verification or anything. Any ideas?
If you mean this guide (worked on both my Tribute and my Volt): http://forum.xda-developers.com/android/development/guide-root-method-lg-devices-t3049772Can't say for sure as I did not use this method myself. Double check that your ports, paths, and syntax are all correct. This would be better asked in that thread, or even better on the post on XDA.
It's not stick, it's waiting. You have to unplug and replug the phone to start the flash.In LGFlashTool, when I pressed the yellow arrow after following everything, it stays stuck on "READY!". Is that normal?
That's the same thing we already have listed in the guide, he just made a bat script to automate the process, which is handy, as is the video. I will link to it. Thanks.Hello everyone! Thanks to avicohh over at xda, there is a One Click LG Root script. There is a guide with video too. Really easy! It should work for ZV4 and ZV5:
http://forum.xda-developers.com/lg-g3/general/guide-root-lg-firmwares-kitkat-lollipop-t3056951
Thanks again to avicohh!!!
All the files needed are linked in the guide, which is largely unnecessary at this point since all versions have a direct rooting method. The guide is just there in case those methods don't work for someone for some reason.hEllo I need the link to the radio and is this process UNLOCK THE PHONE? NEED TO UNLOCK THE PHONE
In order to take your phone to another carrier, it must be activated on its original carrier for at least one year. There is no unlocking, and we don't discuss that here.Want to make use of another carrier? How do i unlock the LG VOLT LS740 VIRGIN MOBIL IMEI 99
Ok, so I have two Volts, one is running v3, rooted with towelroot and I'm leaving it that way. The screen broke on the first so I bought another one that came stock with v4. I'm trying the process to downgrade the second one to v3 but when I try to go to download mode using volume + and plugging in the USB it never gets to the download screen, it stays on the "keep holding the button down until the download screen loads" message.. am I missing something that makes it change to the download screen?
Just to reiterate, you don't need to use the downgrade method, just the method listed at the top with each zv version. I don't know why you're not able to boot into DL mode, unless you're not actually holding the Vol+ or something is wrong with the phone. It should boot into DL mode within about 15 sec. I would take to back to wherever you got it and tell them it won't boot into download mode and get a replacement.On another note, I'm having the same problem with the new method, everything goes ok until I have to manually go into download mode and it won't get to that screen it just stays in the one that duds to hold down the volume button.
No, nothing on the computer has to do with whether or not you can not into download mode, just what you can simplify once you get there. You might try doing a factory reset in the stock recovery. I don't know if it will help, but I have no idea why it's not going for you. Do you have the phone in a case? It could be preventing you from holding the button correctly.I understand, the problem with the script method is that it has me manually boot into DL mode and when I do that it says "loading...." and to hold down the volume button but it never gets to the firmware update screen, I was just wondering if anyone else had heard of that and if there's something that could be done. Otherwise, I think I'll just have to deal with it, I got the phone on Amazon quite a few months ago, switched carriers and then switched back so I doubt I can send it back for replacement although I might email the seller and see what they say.. I thought maybe it might have been something to do with a driver or something that won't let it get to the firmware update screen.
Yeah, I've tried it with and without a case, factory reset a few times.. I guess I'll probably just try it again every once in awhile unless another method arises which is unlikely since this one works so well, or a comparable/better phone gets built lol. It's still a pretty good device without root.No, nothing on the computer has to do with whether or not you can not into download mode, just what you can simplify once you get there. You might try doing a factory reset in the stock recovery. I don't know if it will help, but I have no idea why it's not going for you. Do you have the phone in a case? It could be preventing you from holding the button correctly.
What's going wrong with the zv5 method?Am downgrading it because am not able to root the V5, "Waiting for connection" that is what the software says every time
Download Flashify from the play storeJust Try the zV5 Root Again And it successfully root my Ls740ZV5. But 1 thing More How do i flash TWRP? Big Thanks
