i did that
ok and what happened?
are you sure that you named the file correctly?
and that it is on the card no folders?
i did that
pull battery out leave out for 10 seconds then put back ini did all of that. i updated it. click on reboot. went to recovery then phone just reboot.
[correction]
i clicked no on reboot
ok lets try this, we will try and use a ruu to see if we can get a working phone. this will give you a stock rom and stock recovery. so if this will work we can then try and install a custom recovery (amon ra 2.3) afterwards.
here is the ruu:
PC36IMG_SuperSonic_GB_Sprint_WWE_4.54.651.1_Radio_2.15.00.0808_NV_2.15_release_220182_signed.zip
do the same thing as with the amon ra file (make sure that you delete this file first), rename it to PC36IMG file. make sure that you do not get the two files mixed up as they will be named the same.
edit: wait your phone can boot up? sorry i thought that you were in a bootloop
edit #2: if argedions suggestion does not work then you can try mine if you like.
tap on the programs icon superuser will pop up and ask if its ok to give it superuser permissions tap the ok or yes button then in quickboot choose recovery and it should reboot and send you to recovery.ITS downloading. i dont get what do i do after i download it?
i rooted
ok lets step back and findout what you are lost at?im lost
