It gotta be a kernel error I been reading on the HAL error it has to be kernel
Maybe I dunno nothing bout that stuff I just know that needs release us source already wtf LG
yeah all these phones dont have the same camera
the 505 Euro kernel has support for the two cameras that I have
S5K4E5YA
IMX119
but has support for only one of your camera IMX119
your other camera OV5693 is not supported by the Euro kernel
I tried taking the OV5693 driver from the JB kernel and adding it to the kernel source
and I switched the liboemcamera.so with the JB version
https://github.com/hroark13/lge_f6mt_cm11/commit/299274868814a40f50538e167cc685e97c3e8ee2
I was hoping it would work for you, but I guess not
I may not be able to fix this with out having a phone with that camera in it
AFAIK, LG just does not allow non-LG apps to access IR blaster, so there is a chance that by using LG QRemote and sdk it will work.
overall, tremendous project, tremendous progress in such a short time.
Hroark13 rocks.
But for now I have:
- GPS not really working;
- QRemote not working;
- Isis Mobile Wallet not being able to install (although it seems to be a problem for all devices on all CM ROMs).
Unless those issues are fixed, I am going back to stock.
Sir sorry for the stupid question, that means that can i (and the other owners of F6 Euro D505) have some hope to see your cm11 on our device? There are some plans to make it work on D505 too?
I'm writing this only to understand if the sources from LG included in your tree are still used to be compatible with D505 or if the other pieces of hw are excluded in the build process...
Btw, thanks for your patience and your amazing work on this device... In 6 years looking in the other devices scene I Didn't see anything like that, so fast and accurate! Amazing Sir, Keep it up!
Coding help hroark he been ttyna help us get our can working
Looks like you were trying to run update.zip, which I've never used on custom recovery. You may need to format data then restore/flash additional files; twrp has option to format data, but I'm not certain of cwm.Hey guys, I'm sorta in a dilemma. Maybe someone can help me.
Last night I decided that I wanted to try out the rom, and I've flashed a few roms already, so I didn't figure I was going to have so many issues. I am going from Xperion's last build with CWM to this rom. I started with a factory reset then I went through the process of changing from CWM to TWRP, and then attempting to flash CM11. CM11 installed fine but GApps gave me an error "Error in /temp/update.zip". So I decided to factory reset again and then sideload CM11 again, now CM11 is saying that it can't mount /data/.
So now I have to figure to flash the stock 12b rom, but both R7D Test tools don't seem to want to work. If anyone would be able to help then I'd appreciate it.
I don't 100% understand your situation; it's a bit over my head. Have you tried formatting data under wipe menu in twrp and then factory reset from same menu? I had to boot into twrp with button combination which led to data partition being unmountable, but formatting it fixed the issue.I already have TWRP up, which is what I'm used to from my Nexus 7 (2013). The problem I'm having now is that I'm unable to mount the /data folder, which is why I cant' format /data.
Edit: Here is the R&D Log
[R&D Test Tools Log File]
12:38:23 : Start fn_StartUpgrade
12:38:23 : Extract kdz file
12:38:27 : kdz decrypt Success
12:38:28 : Extract file Success.
12:38:28 : LGMobileDL Load.
12:38:28 : Port = -1
12:38:28 : Connection check start.
12:38:43 : Check Phone mode = 2
12:38:43 : Phone type check.......
12:38:44 : LGMobileDL.DLL Loading....
12:38:45 : _SetAuthMark Fail
12:38:45 : _SetAuthMark Ok : wAuthMark(65535)
12:38:45 : _DetachDLL Call
12:38:50 : _DetachDLL Call End
12:38:50 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\MS50012b_Develop.wdb
12:38:50 : Param : moduleDir =
12:38:50 : Param : waitTime = 526173217
12:38:50 : Param : UsbHighSpeed = 1
12:38:50 : Param : PhoneMode = 2
12:38:50 : Param : BinVersion = MS50012b_00
12:38:50 : Param : AuthMark = 65535
12:38:50 : Call fn_StartUpgrade
Edit2: Seems to be because of USB 3.0 port. It seems to be working correctly now.
Because CM does not include carrier software, my HTC one Google edition didn't have WiFi calling eitherI have a question why is it difficult to include wifi calling ? In cm 11 .as someone stated . I mean its one of the main features n im sure its the most usefull whenu have no signal coverage ,
