He completely disabled itIs there a way to get the Notification LED working in the latest build, or will it be enabled in a later one?
Led ? That's the feature you miss lol
Most likely we are not gonna have WiFi calling I'm CM or any AOSP ROMi miss it too only way i kno i have messages cuz i disable sound n vibration also miss wifi call since at work i get no reception untill then im goin back to xperion rom will wait for more stable release
Lol have fun on 4.1, as far as I know, no cm11 ROM has WiFi calling. Even if one does the likely hood of this phone out of an odd that we don't even know is crazy.Then most likely i wont install any of those rom lol n this phone will stay on 4.1
Hroak did u get to look at the logcat
Shouldn't you be able to tell off the bat?
12 hours on battery with 5hours of screen on time
Is it good or bad?
Have you tried factory wiping and reflashing again? You seem to be the only person having cam issues.By the way that's a way better looking cam than stock but maybe I'm missing drivers or a config is wrong ?
