On the new build the people I talk with on the phone says that they hear a echo
Of themselves for me sound fix not
Tried on build before also tried angabladesdid you flash hroark's fix?
Supposedly, there's a thread about it on the metropcs section, it even says CM11 on the tittleSorry if this has been asked before I looked through thread and didn't see anything. Does link2sd work with this rom.
Did anyone else's auto brightness stop working? Mine did. I guess I should try flashing again.
thank you for addressing it as fast as you did i have not test it out but i will tonight to confrim every thing is a goodrolgar already fully tested sound and said it is good
So sound is working with no issues, and does not need to be addressed anymore
don't bother, it was taken out accidentally, ill put it back next build
I though the f6 didn't have an autobrighness sensorSounds good. Can't wait till next build!![]()
Kernel crashes after every call.
http://androidforums.com/metropcs-o...62663-mod-external-internal-storage-cm11.html
Your talking about this one. Have you used it.
I am curious if this cm11 build is designed to work with the kitkat you have posted in this thread? before i go updating
thanks
CM11 is kit kat, it says 4.4.4
