silver03wrx
everytime this happens to me i format the /data partition in cwm then reflash my rom. and gapps . or rflash xperion. works everytime. and no need to kidz thank god
i havent messed with l2sd since cm isnt final n will b flashing a lot but on jb with xperion i used l2sd n i personally used aparted but u can partition sd card on compm. the first partition is the one it will use so make that the size u want added to internal.. i had to set it as ext4 not fat32 to be able to link game data with the pro version.. worked great for me.. there is also a thread on l2sd here i believe
Yeah, they do. Except for certain gravity box features.Does anyone know if Xposed framework works on beta3, unlike the previous builds?
Xposed has always worked. If you're restoring Xposed from 4.1.2 then you need to clear data and cache for the app.Does anyone know if Xposed framework works on beta3, unlike the previous builds?
I can confirm that the kernel crash when trying to use the speaker phone is a consistently reproducible bug.
You have to pull the battery each time to reboot the phone.
Why would it not work?
Theres a download 2 sd app, might helpWell on beta 1 I read that someone had tried to install xposed and discovered it wasn't working. however, I tried it for myself and when I rebooted to finish the install, I got stuck in a boot loop and had to unbrick with kdz. Ever since then I've been weary about installing it (not wanting to get soft bricked). That's all. I just thought I'd ask before I screw up and have to restore my phone back how I like it.
Next question: does anyone know about if that link folder 2 sd module works on kit Kat, with all the write to SD restrictions and all? (I mean i used the play store fix by jrummy for 3rd party apps. But I hope I can link the folders with that mod like I did on GTs ROM.)
Any camera fix yet
I installed beta 3 and all I get is an infinite boot loop... How can I get to recovery from there???
Boot into recovery and restore a working backup?Well I've tried about everything I could think of to get my recovery program, cwm, to boot but with no luck. So then I tried to install the gapps using adb. This just ended up giving me a bunch of errors saying xzy app as stopped running unexpectedly. So then I thought I would do a factory reset. I did this earlier in the day and everything seemed to go ok but now my phone just gets stuck at the cyanogenmod splash screen and never finishes booting.... Please let me know if you have any ideas.
Thanks!
