lokipimpin
Here the antennas spectrums havnt been updated. Yet,,,,
I knw what are my preferences n how to tweak(manage) them.
Yeah what he said!...lol:smokingsomb:
Can I just flash this rom over my rooted stock Link2SD 12b and keep all the settings? I don't want to flash and then spend hours getting everything the way I like it.
Thnk U for making fun of me.
. But they do need to update system where I am too!Anybody having issues with the home launcher crashing? In this case, it's Nova.
Crashed on me on Saturday, and I wasn't able to do anything. Kept getting crashes on a loop. Long story short, I had to reset my phone in order to get to my recover to flash a backup.
Well, that erased everything from my internal memory. No big deal. But, when I flashed my backup, the home launcher still kept crashing. This time it was the stock LG launcher. My backup is stock ROM.
I had to wipe everything and flash this ROM again. Everything was good... until yesterday, when it happened again. Home launcher kept crashing.
Again, I had to wipe and flash Xperion ROM.
**Edit** I'm not saying the issue is related to this ROM, since it also happened with the stock ROM and launcher. I'm putting this here since it first happened while running this ROM.
TIA
When you're debloated on stock rom or on any custom rom for this phone you cannot wipe data/factory reset or the launchers will crash along with some other apps.
Not much else I can say since noone's had this issue as a result of this rom.
Does anyone know where I can find the odex files on this device?
I use an equalizer app(Equalizer Pro) instead of dsp manager when i listen to music through earphones, I like the feel and features of the app I use. But the problem I'm having is the equalizer takes effect fine when i listen music on pandora, but when i listen to my music on "google play music(the media player I prefer to use)", the app I use doesn't work, but dsp works fine. Do you have any idea why that would happen? and is it safe to uninstall apollo and dsp since I don't use them? I save my music to google play and play it through the cloud so I'm not too much interested in another media player.
Hey guys,
I just downloaded the Xperion Rom and put it on my phone yesterday. So far I'm liking it, I just have to flash the Kernal.
It also gave me a chance to re-partition and format my SD card again, since I made my original FAT32 too small.
Anyway, the Xposed framework, it didn't come with it, and I have to install it, but it says I could soft brick the device. Has anyone had any luck/problems with putting xposed on this phone?
Can? Yes. Necessary? No. You're gonna end up at the same point, anyhow.GT, I'm going to reflash your latest ROM in order to get a fresh start. Does it help at all to use KDZ to go back to 12 stock first?
Press 611 on your phone and enter your real address in the e911 prompt. Just had to do this myself. You'll never have to do this again after doing so.
