trapaholic408
When i factory reset via cwm it says could not mount/data skipping format
Looks great! A couple of quick questions:
1. What is "unsecured kernel"?
2. I've been using the "Loki" CWM. Are there any advantages with TWRP?
Change Log
8/18/2014
- Added SuperSU shortcut in settings menu
Hey GameTheory could you incorporate superSU or superuser which one ever you prefer to the settings menu? I thought it was a neat idea, thanks this is just a suggestion.
Guessing that's a no... Oh well.
Yeah that's a negative. SuperSU only needs to be setup once when you first install it then you rarely need to open it after that.
That's right I remember
Wow you must be bored since you went digging for that lol. This is one of the reasons why I try not to respond to requests. That was my mistake for responding to your post that time. Funny thing is I added it cause I remembered you asked. Plus I had to add something in place of nova shortcut.
ROM Updated
8/18/2014
Changes:
- Adjusted recovery shortcut in settings menu since we now also have TWRP recovery
- Added Xperion ringtone and notification
- Added unsecured kernel with init.d and other features
- Removed Nova shortcut from settings menu for those that want to use other launchers (nova still included in rom)
Instructions:
- You can install the rom right over any other rom available, I made it easier and more noob friendly to install. Follow the new instructions listed. That's it.
Screenshots:
I'm assuming this update (8/18) requires full wipe rather than just system?
1. What is "unsecured kernel?"
Check my blog
Will it be ok to make a backup and restore /data? or were there some changes into that folder?
I installed the updated version, now my Home button does nothing. any reason you can think of why? I have gone to recovery and wiped and reinstalled several times. same result. Fixed the problem. Yeaaaaaa
What is the MD5 hash for the latest ROM?
This is what I got: 91FAF089B9BD50A338F07A423C6AB621
md5sum FILENAME
That's not an unsecured kernel. Loki patch is just to bypass the locked bootloader. Unsecuring a kernel is something different. Please google it.
Unsecured means adb has root privileges?
Yep, and has nothing to do with loki.
I've been on the Cm11 Rom, went back to your Xpieron you have done A LOT! GREAT JOB i'm not sure if it's mine alone but it didn't come with a browser which is fine anyway i hope you keep updating.
Thanks
Yeah I left the browser out since people have different choices of browsers they like. (chrome, firefox, opera, dolphin etc etc)
Can I update this ROM by installing the zip on top of the current ROM...like a dirty install...I hate to do everything all over again...Thanks again for all your work
I'm not going to disrespect all the Devs putting in work...but I nominate Spherion in the F6 Hall of Fame !!!
