You can do the nandroid backup...it will create a folder on your sd card named "nandroid backup" or something nandroid..
You can always transfer that folder to a new card should you decide to do so.
That backup can only be used with the phone that made the backup.
okay then ill try that...but theres like 5 options which one do i choose?
