here is a little more details on how to get a recovery onto your phone. there is a couple ways of doing it. you can use the fastboot command to install recovery or you can use the android flasher program. either way, it is pretty simple. i will leave the decision up to you.
method 1
you can install amon ra 2.3 by the following:
1.download amon ra 2.3 from here:
PC36IMG_RA_2.3.zip
2.extract the recovery.img file and place it in the
android folder you created when unlocking your bootloader.
3.on your phone after you have unlocked your phone you should be in the bootloader menu screen, select the fastboot option
4.on your computer press and hold shift while right clicking the
android folder.
5.select
open command window here option (windows 7)
6.enter command:
Code:
fastboot flash recovery recovery.img
congrats!!!!!! you have just installed amon ra 2.3
method 2
how to install amon ra2.3 with android flasher
Android Flasher, what is this and how do i use this?
well with android flasher, you can flash radios, your splash screen (that is what the htc white screen is called right before sprint's boot animation), and your recovery. you will need to extract the .img file from the .zip file. in this case i will show you how to install a custom recovery amon ra2.3.
so here is what you will need to do:
1.download android flasher from here:
AF Downloader
2.and extract it to someplace on your desktop where you can find it.
3.next you will need to download amon ra 2.3from here:
PC36IMG_RA_2.3.zip
4.extract the img.file and place it some where you will be able to find it.
5.run android flasher
6.go to the recovery slot and select browse and then navigate to the amon ra .img file
7.select it and then select recovery
8.then at the very bottom select flash
congrats!!!!!! you now have amon ra 2.3 installed.
