Root [ROM][ACS] GB UNleashed 2point3 [GBU-3/20/11] " KING STYLE "
hey guys, idk if it's the "wake lock" issue or something else, but i have been getting very bad battery life on my phone. I checked the battery usage and its saying that its awake constantly even when the screen is off. Help :[
I was having some wake lock issues with google services. Have you checked partial wake usage with spare parts?
Android System has the most. Flow for Android has the 2nd most partial wake usage cuz of how its push notifications work probably. But idk for sure. Then come tango and gmail.
What is the actual total wake lock time for each vs the total uptime?
Im not quite sure how to figure that out, but for Android System its 1 hour, for Flow its 28 minutes. Tango is 25 minutes. Gmail is 7.
I dont think thats what you were asking tho..
Is that what you're seeing in spare parts when you select each one under partial wake usage? How long as the phone been on or unplugged?
I am new to Tb.. decided to up grade after the vvm problem and seeing how every body loves TB... so was wondering if some one could post a good thread on how to use it seeing that there are so many options... I sprung for the pro version.. and there are so many settings.. I would like to know what I am doing before I do it......
ya thats what spare parts is telling me. The phone has been off the charger since about 7am, but i havent used it that much cuz im at school. I'd say the total time i used it was maybe 20 minutes.
This WiFi is pissin me off...... I reinstalled the ROM... I can switch from 3g to WiFi.. cool but when I install wireless tether not only does that not work but also WiFi wont work any more.. any ideas????????
That seems a tad higher than normal, but I've noticed that Android System seems to hold longer wake locks on AOSP ROMs, for whatever reason. Aside from that, are you saying that wake time equals uptime? If so, we'll need to find out what. what do you see for the % of time running under other usage? What about sensor usage? What do you see there?
other usage
Running - 31.8%
Screen On - 6.4%
Phone On - 1.7%
Wifi On - 14.6%
Wifi Running - 14.6%
Sensor Usage
Android System - 1 hour
Flow - 25m
Dialer - 12m
i first noticed in when i was checking the battery usage in the settings. The little bars at the bottom underneath the graph of battery% vs time detailing how much each thing was used over a period of time said that awake was constant even when screen was off.
other usage
Running - 31.8%
Screen On - 6.4%
Phone On - 1.7%
Wifi On - 14.6%
Sensor Usage
Flow - 25m
Dialer - 12m
Yeah, that seems to be what mine is doing now. Android System is holder longer wake locks that usual. I thought I had it figured out, but not quite yet.
super awesome battery life for me :)
took the phone off the charger at 7 am...it's 1130 and i just hit 50% (extended)
I'm getting mixed results. Sometimes I get great battery life, other times I'm getting inexplicable battery drain.
which kernel? I am using savaged zen 1.1 I believe
I didn't care for the cm7 kernel he includes in the rom
You must be using SZ 1.0.1. I'm using 1.0.0, at the very moment. I might try 1.0.1 again, as it seemed to fair a little better. I'm having a lot more trouble with inexplicable wake locks. I'll figure it out eventually :).
Got wifi working just had to download the new experimental version 3 .0
I have issues with wifi sometimes, i have the 170 dollar linksys router i cant remember the model number, point is it should be good lol. If im not sitting within 5 feet of that bitch i cant get a good connection, doesnt seem right. I chalked it up to time warner (road runner turbo boost)sucking but the xbox and laptop dont seem to mind being in a different room...what is this experimental version you speak of?
I dont know much about wifi but it just dont seem right, i should get crazy speed with rr turbo and that router (not that the router is doing anything for speed per se but it should give me signal in the other room)...? Sometimes i cant even load a web page, i switch to 3g at home sometimes, how sad is that?
Xbox is directly connected not on wifi, the only things using the wifi are my phone the gf phone and the laptop...
i checked my phone after i had the screen of for 3 hours only to see that android system had 98.5% partial wake time :|
i switched to CM7 :/
I haven't really tried this ROM out but all you guys are about to push me over the edge since I've basically been running CM7 for the last two weeks and not really changing anything.
How is the 4G connectivity? It was just fixed in CM7 N35, so it wouldn't be somehow fixed in this ROM as well since it's based on an earlier CM7 build right?
Also, with CM7 I am running Tiamat instead of SavagedZen and am not having any wake lock issues. Why is SZ so much more popular? I feel like I'm missing the boat.
