ne0natas
I think I'm bo7. I guess I'll give it a shot.Are u b05 and below if not root master won't work
Let us know we will help outI think I'm bo7. I guess I'll give it a shot.
Zte really locked this one down by removing the update zipI think I'm bo7. I guess I'll give it a shot.
https://sites.google.com/site/androidxdacom/file/Kingroot_V4.5.0.803.apk?attredirects=0 latest version of king root try thisI think I'm bo7. I guess I'll give it a shot.
Is SuperSU ok instead? It has a better rating. Hmm... Says no binary installed though. Because I'm not rooted yet I assume.Did u install super user
Just get a warp 4g or get an awe on amazonAhhhhh! Kingroot doesn't work either... This is ridiculous. I'm about ready to just say **** it.
In my about section baseband version is b01 and sw version is bo7. Does this tell you anymore?Just get a warp 4g
B07 is not what u want can't root the phone unless u use a PCIn my about section baseband version is b01 and sw version is bo7. Does this tell you anymore?
I guess I'll look into it more if I feel up to it. Thanks for trying to help though.B07 is not what u want can't root the phone unless u use a PC
I'm send a different version of kingrootI guess I'll look into it more if I feel up to it. Thanks for trying to help though.
https://sites.google.com/site/androidxdacom/file/Kingroot_V4.5.0.722.apk?attredirects=0I guess I'll look into it more if I feel up to it. Thanks for trying to help though.
King root normally for kk devicesI guess I'll look into it more if I feel up to it. Thanks for trying to help though.
All u need is adb driversI guess I'll look into it more if I feel up to it. Thanks for trying to help though.
Ok so u installed pdanet and then hooked up ur awe and the drivers dont install???I tried the other version of Kingroot you provided and had no luck with that one either. As for adb drivers, I have the drivers installed. I'm going to look at some other rooting threads for rooting over pc and hopefully I'll figure it out. Really wanted to install L Awe but when it goes to install this driver it wants to install, it can't find it so I probably shouldn't proceed with that right now.
I'm "rootin" for you, man. I learned so much on the Awe last year and L Awe was my favorite ROM. Better than the real Lollipop. Good Luck!I tried the other version of Kingroot you provided and had no luck with that one either. As for adb drivers, I have the drivers installed. I'm going to look at some other rooting threads for rooting over pc and hopefully I'll figure it out. Really wanted to install L Awe but when it goes to install this driver it wants to install, it can't find it so I probably shouldn't proceed with that right now.
Also, I'm on the Zmax now. It roots with Kingroot, at least temporarily, but it rarely roots on the 1st try. Try clearing kingroot's cache and data and force stop it, then load up your RAM by running alot of apps at the same time. Then try kingroot while your phone's overworked. Try it a few times. That's what it takes to gain temp root on the Zmax. You may get lucky.I tried the other version of Kingroot you provided and had no luck with that one either. As for adb drivers, I have the drivers installed. I'm going to look at some other rooting threads for rooting over pc and hopefully I'll figure it out. Really wanted to install L Awe but when it goes to install this driver it wants to install, it can't find it so I probably shouldn't proceed with that right now.
lp is 99 ℅ functional on the warp 4g pretty wicked M preview are already releasedI'm "rootin" for you, man. I learned so much on the Awe last year and L Awe was my favorite ROM. Better than the real Lollipop. Good Luck!
Its just temporary for a sec once twrp is flashed you have full control over ur deviceAlso, I'm on the Zmax now. It roots with Kingroot, at least temporarily, but it rarely roots on the 1st try. Try clearing kingroot's cache and data and force stop it, then load up your RAM by running alot of apps at the same time. Then try kingroot while your phone's overworked. Try it a few times. That's what it takes to gain temp root on the Zmax. You may get lucky.
Oh, believe me, I know it... Lol. I was just talking about the kingroot part of the Zmax root process. If it were to work on the Awe, I'd be surprised if it wasn't permanent. But even if it wasn't, androidforums has everything you would need for the Awe to make it permanent if you could even gain a temp root.Its just temporary for a sec once twrp is flashed you have full control over ur device
I'm done with the awe king root is normally for kk devices well 4.4.4 is harder more attemptsOh, believe me, I know it... Lol. I was just talking about the kingroot part of the Zmax root process. If it were to work on the Awe, I'd be surprised if it wasn't permanent. But even if it wasn't, androidforums has everything you would need for the Awe to make it permanent if you could even gain a temp root.
I'm done with the Awe too, but it'll always be one of my favorites.I'm done with the awe king root is normally for kk devices well 4.4.4 is harder more attempts
