yeah my battery life has been excellen on b6 as well. Over 15 hours and I'm still at 59%.
Same here, I can get about 25 hrs to a charge, using 2x Battery
Tickerguy,Incidentally, I have some bad news.
There is a high probability that I'm leaving Virgin, and thus the Triumph. T-Mobile may have successfully lured me back with a $45/month unlimited everything plan, and I still have my Vibrant (which is also running CM7 now, natch.)
Their network is a known quantity to me (I was a customer of theirs for nearly a decade) and their 4g/3g footprint has massively expanded here in the last two months. It's much faster (like 4x Sprint locally - I'm seeing ~4Mbps sustained over the cell side on UMTS) and of course I have both national coverage and roaming, where I don't have the latter on Virgin.
And now it's cheaper to boot.
I haven't decided yet, but did go get a SIM and have 2 weeks to figure out if I want to keep it or not. If I do my Triumph will be for sale and that will be the end of my work on the ROM, since I won't have the service any longer (and probably not the phone either of course.) I will of course sell the Triumph with GB loaded on it and the Froyo load on the SD card to be flashed back if the buyer wishes.
This is probably not what you want to hear, but it is what it is; Github still has my code of course and I am not going to remove it, so anyone who wants to pick this up is of course welcome to do so.
Anyone else notice that 'mount USB storage' in CWM does not seem to work? Just a minor inconvenience but still annoying.
Know what I had that funny thing happen. I learned that it might just be the USB cord you are using. For some reason this phone turns it's nose up at any non-Motorola cord. I don't get it either.
Try a different cord or two, Or three...Then see if it's still broken. IF so, Then there isn't much to be said.
, but might jump on the gingerbread bandwagon any day now.I upgraded to the new version (7.1.0) and my wifi no longer works. I get a error when turning it on. It actually says error. Then I can't turn it off anymore or get the error to go away. I installed this after a clean wipe. Any idea? please assist if this is a known issue, etc.
Anyone know what I am doing wrong? I did reset and cleared cache with latest upgrade. I cannot get my google contacts to sync. I flashed GAPPS immediately after installing CM7. Any ideas?
Are you talking about on the phone or in gmail?
