Thanks, I used winrar, and opened the archive, and just dragged, and dropped to update the the file. Formatted /system only, and flashed it (really didn't want to have to wipe everything). So far, it's working like a charm. I've re-hidden my SSID, and it connects just fine.
Thank you so much for this find!
Is there any way to get rid of superuser? I think not, but thought I'd check to make sure.
Just so I have this straight, discovering hidden SSID is only useful if you know the password anyway. Like when (and if) you've hidden the SSID on your own router, correct?
I think if you are rooted, You need it. =] All these roms are rooted.
Depending on the type of encryption that you are using on your wireless router, people may still be able to hack into your network. For example, if you have an older wireless router that can only use WEP encryption, I'd advise that you hide it since I've heard that, using the right tools, people can crack WEP encryption pretty quickly and gain access to your network.
And basically, it's just another layer of security that you can easily set. So if it's available, why not use it?
OK so this, for the most part, is for security savvy users on their own networks at their home or business? Thanks!
Superuser allows other programs to have access to files in your phone that I can do what it was installed to do. Setcpu is used to speed up the phone by programing a file in the root of the phone's file directories to manipulate the speed.
I know, thanks.
Never mind, I found it. Just experimenting a little... its ok. ; ) Just wondered why the apk didn't show in Ti back up.
I appreciate the concern, but I've never needed it before. Just seems to be a bit of a nuisance. Apparently it is in the kernel of this ROM? If so, that's fine. Not trolling, just asking...
[snip]... the Triumph was actually rooted from the get go and had no need for Superuser.
Hello all. I'm still waiting for my Triumph to get here. I see that GPS is confirmed as "working" as of the 9/20 build. Just curious to know, does it still takes 2 minutes for the Triumph to acquire a GPS fix? Also, once it acquires a fix, does it stay locked on long enough to, say, use Navigation without wanting to throw the phone out the window?
Ticker, sad to hear you may jumping ship on the Triumph...
Is hitting the power button the same hitting sleep in the dropdown cm bar? I seem to remember my friend's droid2 having sleep and screen off options in the power menu. I might be mistaken though.
Also, I saw one of the themes had extra buttons on the bottom of the launcher, but when I went to apply it, it didn't take effect. So I figure it's just an example of what's possible. How do you do this? I'd love to move gmail and messaging to the bottom with phone, appdrawer, and browser.
Thanks. Been on cm7 for the past few hours and am losing 20% an hour with no wifi. Hopefully it's just honeymoon period
