0 to 255 is the range. With 255 being max brightness.
Did TG finally decide to leave VM for good? Last I talked to him, he was leaning in that direction, but he hadn't finalized his decision and was still exploring new options.
Sorry for the double post but it's kinda a different subject. Is it just me or is all video playback, youtube or anything else, choppy/buggy when viewed in vertical mode, but horizontal is perfectly fine?
If TG does leave then you are the next candidate. You two have many fans and dedicated modders that will follow you. We may give you a hard time at times but we are always willing to help. Plus this rom isn't 100% stable and is not in the rom manager download section yet. We are proud of you guys for all the work and patience two have put into this rom. Thank you.
Help with battery life...I have two motorola triumph running the newest cm7 from TG. They both are running juice defenders and smartass. One of the phone last the whole day with a full charge with moderate use. The other last about 4-5 hours with hardly any use...it drains battery like crazy MF. I have wiped the phone clean and cleared all cache...still no luck. Any idea what else I can try? TIA
Hi: Try swapping out the batteries to the other phone to see if one battery is bad. You may also need to calibrate the battery meter in one of the phones. If the batteries are both good then check and see if there is an app that is not on both phones to see if an app is running your battery down.
How do you calibrate the battery meter? I tried swapping the battery this evening...no luck. The phone that was having the problem, still has it. So is not the battery. I am going to calibrate the battery but don't know how. If that doesn't work, will have to delete all apps and try loading one by one![]()
Wipe the battery stats,let your phone die.
Then charge it fully, phone goes into trickle charge after 90%.
So keep it plugged in overnight.
Me too. I am thinking everyone does. That's one reason why I'm using Miui.
To all: I saw that there is a new wireless company which starts on the 8th, called Republic Wireless, I believe. They will have unlimited everything for...GET THIS: $19/month...
Anyway, just curious if that is why you are leaving, TG.
Doesn't MIUI suffer from the same problems since it's based on the same code? I could have sworn it did back when I tried it... if not that's pretty awesome!
Ticker is considering leaving for TMobile's new $30 plan which is 100 voice minutes and 5GB 4G capable data. Since T-mo's network is GSM you can pretty much use any unlocked GSM phone you want with this plan... so any number of countless high end Android handsets, iPhones, etc. It's pretty sweet.... I just hope it doesn't go to crap when the Death Star (AT&T) finally get to buy the company mid 2012.
Republic Wireless will be CDMA phones on the Sprint network (same network as Virgin Mobile). The phones will run specially modified versions of Android so that whenever the handset has a WiFi connection they will use it for voice calls instead of the CDMA network. So you can think of them as sort of hybrid VOIP phones. We will know for sure in a few days but I can imagine that at $19 these handsets will be locked down tight and probably pretty low end. I'd love to be proven wrong though...
Hell, maybe they will push VM to lower it's cheapie plan back to $25 instead of $35!![]()
