This is correct. I've been reading up on ICS and I'm researching what things will need to be updated in order for ICS to work correctly on the Triumph. From what I've read, touchscreen/input problems and audio (or lack thereof) seem to be the biggest issues. Input device processing has changed for 4.0 and the current touchscreen driver for our kernel will need to be updated.
[DEV]Porting Touchscreen driver for Android 4.0 (ICS) ROMS - xda-developers
will that help you with the touchscreen for ics !![]()
Yes. That's actually what I'm looking at right now.
I know you already have CWM, but follow the steps in this post. Skip the stuff about CWM since you already have it on your phone, and it will guide you through the rest of this.ok, im new to this so bare with me a little, ive been reading alot, i have CMW 5.0.2.6 and Rom Manager, the gapps is what is confusing me, on the post he has 3 links, do i download them all, or just the base gapps? what order do i flash them in ect..?
Just the first one, unless you want Google Talk as well, then both of them.NOTE: On this release and forward the "Gapps" (Google Apps) must be separately downloaded and flashed after you load the ROM (before booting the first time is recommended):
http://goo-inside.me/gapps/gapps-gb-20110828-signed.zip - Base Google Apps
http://goo-inside.me/gapps/gapps-gb-20110828-newtalk-signed.zip - Google Talk (if you want it)
IF YOU FORMAT /SYSTEM AND DO NOT REFLASH BASE GAPPS AFTERWARD MANY THINGS WILL BREAK. That package contains all of the Google connections to Android - the authentication for your contact list, email, sync settings and more.
It is generally safe to not format /system if and only if you are coming from one of my previous ROMs in the same series (e.g. Beta, etc) and you have not manually tampered with any files in the /system area or the kernel. If that does not apply then you should format /system and reflash GAPPS or I can virtually guarantee that you will not like the results. If you have changed files under /system, especially if you have replaced any of the stock applications (e.g. the dialer, etc) or the kernel there is a very high probability that the remainder of the load will be out-of-sync with what you did and that can cause serious stability problems. There is no way for me to know what you did in this instance and I cannot realistically provide individual assistance if you have modified system files in the load or on your phone. Please be aware that the framework, kernel and loadable modules are different than stock and in many cases from one version to another as this is a work in progress.
Hey guys.. Has anybody upgraded to a newer beta and followed TG's suggestions to FORMAT DATA if coming from previous builds and LOST the GOOGLE account, thus not being able to use Market Place etc? This has happened to me everytime and wind up having to completely FORTMAT SYSTEM and Install fresh..
Is it safe to just upgrade to 0.8 without formatting data? Or a way to ADD GOOGLE account once it has been deleted?
*i did try to add google account when lost it during format data and install of new build but it the option wasn't there*
Thank you in advance.
Thanks so much for this ROM! I was at my wits end with the screen flicker issue and I was about to return it when I decided to see if CM7 could possibly fix it and sure enough it did!
No real issues to speak of so far, except I can't connect to my home wifi network for some reason. It is currently secured with WPA/WPA2 PSK but when I try to connect it just disconnects automatically. Any ideas?
When you format /data and /system you delete the google apps. CM7 does not include the google apps because they are not open source the license is owned by google. There is a link here to download the google apps which you should definitely do if you want to have a functional phone.
Formatting /system and /data is not required but if you have issues when moving from beta to beta that is the remedy so it's just recommended to avoid headaches later on.
Is the ssid hidden? CM7 won't connect if it is. I think there is a work around, but it is rather involved if you don't really know what you are doing.
If not, try resetting the router. That fixes most issues.
NOTE: On this release and forward the "Gapps" (Google Apps) must be separately downloaded and flashed after you load the ROM (before booting the first time is recommended):I cannot purchase from the android market after the flash, is this fixable?
Anybody here use Launcher7 with this ROM? There has been a lot of talk about improved battery life/performance from this ROM vs stock, but I just don't see it. Hence, my question about Launcher 7.
The only way I have seen battery improvement is if I use JuiceDefender (which delays the use of Launcher7 when it is re-awakened bec. the wifi starts trying to turn itself on) or manually put it in airplane mode.
Don't get me wrong, not knocking this ROM, just wondering if anyone else has a similar experience with this launcher and ROM together.
Thanks in advance!
