konspiracy
how come he didnt update to cm7 7.2?
Is any one going to start cm9 for this phone I'm just drooling over the os...I envy those who have the os on the Samsung galaxy nexus...
I've flashed cm7 and no Kernal, 8 beta, and I don't get ANY gmail notifications, and I get Facebook every now and again but it's mainly when I open it up I get them. I just feel like my notifications arent completely correct. No apps on my sd because they do not work right
Weird issue when dialing contacts with internation prefix.
Most of my contacts have +1(111)111111 number format. This does work. I get call lost after a few seconds. If the number is like 1(111)11111 then it's fine.
The "+" is throwing the phone off I believe it tries to make an international call.
Where or how do I change this behavior in CM7? I couldn't find it.
This doesn't exactly answer your question, but why are you dialing a 1 if you're not making international calls?
You probably missed gapps.zip, which is supposed to be flashed right after the ROM .zip, before booting up the first time. If so, re-wipe and reflash ROM .zip then gapps .zip
done, reflashed the rom, gapps, then i rebooted, and then flashed manteras 1.5 oc, love it. still not any notifications yet, and what about removal of the oc completely, back to the stock rom settings?
My gmail app is non-working, at all. Every time I turn on my phone, and I get a connection to google servers, I get 2 force close messages, both for gmail, right after the other. I don't get any notifications after that point, and the gmail app won't open. Every time I take a call, and the data connection drops, When I hang up, I get the same thing, twice (like it is force closing with the data connection) Every other Google app works just peachy, market, youtube, calendar, etc. Do I need to reflash the G-apps .zip? I'm not sure what to do.. I've been dealing with it by using enhanced email for android, but it sucks for integration. (about a week) Any help?![]()
Well, mine always vibrates on calls, and I think I have only changed the setting in Settings > Sound > Vibrate > Always. I have had issues with JD not starting up lately, but I am looking into that and will have to get back to you. I use SwiftKey X and it starts up every time just fine.when i try to save certain settings in cm7, or launch an app at startup, they don't stick after reboot. The most annoying one that i have found is changing the setting to vibrate when i receive notifications/calls "always" rather than "only in silent mode" i change it but when i reboot, it's back to "only in silent mode". as far as apps go, i was unable to have juicedefender or any non-stock keyboard startup with the phone automatically. Any ideas?
My Menu, Home, Back, Search buttons appear to fire on their own along with the haptic feedback.
I have tried factory reset, system reset and restoring nandroid, but no luck. It mainly appears to occur when I first unlock the system. These buttons after an "episode" will often become unresponsive to touch in which case I can shut screen off with the power button, turn screen on and get use of these buttons again.
It appears to have started when I flashed v8. Could it be a badly behaving app? Any suggestions on how to diagnose and/or fix this? Thanks.
A lot of times the issues people have stem from restoring the data from a previous ROM and/or build. That is the first thing I would change if I had issues after a flash. Glad you got it figured out.Figured it out, misbehaving app - Launcher Pro. Actually the app is fine, but restoring the data gave my MT the problem. Took me a few full ROM restores before I finally realized what it was. And setting up Launcher Pro is a good one hour project. But it works! Yeah.
