FroyoShark
Wow, this ROM just keeps getting better! I can even play Galaxy on Fire 2 THD and other Tegra games with Chainfire 3D!
So after loading Tickerguy and Isaac's recovery, I tried to navigate to the mounds/storage area of its inner menu and it keeps going to a nearly blank screen with the hat/arrow logo in the center. I'm switching back to my other recovery, but I'm also wondering what the issue may be here.
There is a change in the controls of the newer recoveries. It is also stated on the top of the first screen after the recovery loads. You must use the menu softkey to select and the back softkey to go back. Pressing power will only go to a screen with a hat.
Oh, by the way, while I was at it I fixed tethering. Well, sorta. It doesn't work for me on USB although it's turned on in the code right now (this may be a driver issue on my PC as it also doesn't throw any errors that tell me why it is failing - it looks like the PC is refusing the RNDIS connection to me)
9/25 load is up with the camera fix.
Yes.In regard to the teathering - I'm seemingly having a problem with it that was similar to the problem all along. Google sites load fine, other sites just wait and wait. (two different machines, each connected at times via bluetooth)
Am I the only one seeing this? Could this be because I, after blowing down 9/25, I then blew down Isaac's OC kernel on top of it?
Thanks for taking the time to answer. The only reason I was unsure was because my understanding is that you are no longer the sole dev for this project. I understand your position, I just wasn't sure if anything had changed since you began working together.My position is that I will not include an OC kernel nor support it for the reasons I stated above. I don't know why anyone would believe I'd change my position on this. Let me make it perfectly clear: I will not include an OC kernel with my builds now or in the future.
If you wish to load one, feel free to do so. Isaac has built one, however at present his does not support MSS clamping. You decide which is more important at the present time (I suspect he will add MSS clamp support, but right now it's not there.)
Secondly- After reading through this thread for the past few days I'm not clear about the overclocking ability of this ROM. I understand that in the first few posts it is stated that tickerguy doesn't want to add OC support to his kernel but now that isaacj87 has joined the project I'm unclear as to if that is still the case. I apologize for what is probably a ridiculous question but if the OC is not in the current CM7 kernel is it safe to flash something like the Umph kernel or does it need to be built specifically for this version of CM7?
From what I've seen and read the CM7 build in its current state seems to perform nearly as well in basic use as an OC kernel in terms of speed but I've already pushed my phone to 1.9Ghz and it is stable there so I'd love to be able to keep that or at least add it back in easily in the future. Again thank you for your hard work and I appreciate any answers I could get about the OC ability of the project now and in the future.
Thank you tickerguy & isaacj87 for the awesome work on this rom.
I have been folowing this thread since day one and I have to say you are quick. I owned the G1 and Droid X and played around with CWM for while now.
I still haven't flashed mine yet, but at this rate of fixes and improvements I will make the leap soon. I'm just waiting for FC and HDMI since I do use those 2 features. I'll wait paitiently, but looking forward to tethering and improve battery life. Thank you guys again.
I can send you a HDMI cable if you want one that is.![]()
