evanrobinson85
NM I found the site.
It worked for getting the codes on many other devices. But thanks for your input.
The dictionary is on the CM7 build.
So, after you install this, will you still be able to keep your old apps?
Hello everyone.
One bug I have been encountering is not being able to send or receive (3g) data after waking the phone. I will have the 3g icon displayed (gray) but when I open up an app using data it will immediately report network issues. Toggling airplane mode will fix this, it also seems to be happening often. I am currently running the 9/25 build, coming from stock.
Thanks for all your work, Tickerguy.
So it turns out Virgin Mobile accepted my payment they just didn't bother to replenish my minutes or data. Of course it's midnight so no customer support... Thanks VirginI don't know why but today the 3g is not working, it says 3g and has bars, but it's white. I have tried disabling and enabling data, airplane mode and reboot. I do know about the bug, however tonight for what ever reason the solution isn't helping![]()
PS is there a way to delete post? Obviously this has nothing to do with CM7 and I am only responding to clarify that it has zero to do with this rom...
No matter what rom you use download GPSfix from the market, set it to 1 minute fix time, and run it before you use your navigation/maps/gps apps. Its an easy way to make sure you get GPS locks near instantly no matter what.I don't know about you guys but my GPS is worse with CM7. Although on stock I had the gps.conf mod and the updated flashed GPS libraries or whatever.
I am not a dev but i think this may possibly help with the front facing camera problem if not just ignore my unknowing babble.
the motorola triumph is based on froyo 2.2 and to use the ffc they made a api in which allowed froyo to utilize the camera.
Now with my understanding gingerbread 2.3 uses the camera just fine also. So is there anyway to incorporate the gingerbread ffc api into this cm7 build or would this be impossible, if so we will just have to wait and see if the source comes out like Ticker says.
sorry if this just doesnt make any sense .
here is a link to a little bit of info... MOTODEV > Documentation & Tools > Android Technical Library > TRIUMPH Front-Facing Camera API
great work so far Ticker and Isaac!
@i2c Make sure you go outside when you test the GPS. You can't get a GPS lock inside like you can get cell service inside- it is much more sensitive- it is, afterall, connecting to satellites rotating around the earth. Its not like you ever need to use the GPS inside anyway.![]()
