tickerguy
Tg, I have absolutely no idea on ICS. I doubt I'll be making an immediate attempt to move to it; I've yet to get a crasp on exactly what it brings to the table other than being "new", and that's not enough for me to sink significant development effort into it.
My understanding is that it will run on anything in the modern processor space (E.g. Snapdragon processors, which the Triumph has) but I would expect them to have optimized it for dual-core large-RAM-space devices. We're on the lower end of that, although we do have the Adreno GPU.
Bob, if you can't find the governor with SetCPU you do NOT have the proper load. It's there in the 10/2 build and can be found either under the CM7 "performance" settings or if you have Setcpu you can find it through that as well. The GPS has been working for several builds. Make sure you have the right file (A0.6 should be in the "Mod Version") and if you loaded a differnet kernel on top of the stock one all bets are off as there have been material changes to the kernel as well.
