JollyRoger87
Hey ticker does your kernel have loop device support? I'm trying to run ubuntu on my triumph and am having issues
I am loving this rom so much. You guys are awesome!
Is Wifi tethering via barnacle supposed to work in this version?
And also hats off to you tickerguy. You sir are awesome!
It works for me.
Tickerguy,
I was wondering if you are going to be merging the code into the main Cyanogenmod distribution? (Consequently the code will build Nightlies on the main site, and triumph would be "Official"I'm really excited about all the progress, keep up the great work! Many thanks!
As far as I know its still in alpha. And he's still trying to get it to be put in rom manager
You mean when the phone is locked? There is no fix for it. I don't remember exactly why, but because of something to do with the code it's just something we're gonna have to deal with.ok, I KNOW that this has been talked about, but I can't find it, how do you fix the WiFi dropping (turning off)?
try re-downloading the recovery.imgNeed help please! I downloaded the issacs MIUI rom while running cyanogenmod on my triumph and had issues with downloading it. I eventually got it to download and for some reason it had issues viewing anything on my sd card using the application that came on cyanogenmod. I then just to be safe went to CWM and backed up my ROM and factory reset it but it had an error about the volume so I reinstalled cyanogen and it worked. After that I tried to restore an older backup. It got stuck in a boot loop. I couldn't backup or restore at all. I changed to the latest version of CWM to see if that would help and now the only thing I can do is go into boot loader mode. If I try to power into CWM it just vibrates. If anyone can help it would be very appreciated!!!
already did, it just vibrates... :/
Thanks to whoever suggested using Connection Checker (from the Market) to solve the 3G connection problems!I installed it a day or two ago, and my 3G hasn't dropped yet. I have it set to check every 5 minutes and have not noticed a drain on the battery! Whoopie!
the recovery.imgredownloaded what?
Ive been testing this ROM for 2 weeks now.. i must say I'm very pleased.
unfortunately im going back to stock. dont understand why phone keeps rebooting through out the day.. can anyone help? cm7 runs so smooth but it freezes up followed by a reboot![]()
First Thank you Tickerguy for all the hard work. And if I didn't love the app so much I certainly wouldn't bother you. The install was great and everything worked well. My question is I have GoWeather as my live wallpaper. On the animation of the sun there is a weird looking circle, blotch, around the sun. Is there screen adjustments that I can make to clear this up? I have included a screenshot of before the install and after to help you see what I am seeing. Thanks for you time in advance.
Before:
After:
