I Thought maybe i did something wrong.. but yeah same here.. all those thing you said is are happening to me.I get reboots too. Sometimes they'll happen for seemingly no reason. Sometimes they happen right after I get a text, sometimes they happen when I press the power button to turn on my screen.
Well that's what I didn't want to hear. My 3g sucks in my area. I'm always on wifi.. I guess I'm out of luck..I don't have lockups or reboots. I also almost never use the wifi. Sounds to me like that is the culprit here.
Same here on the reboot. I'm also debating going back to stock.I get a reboot once a day. And I can't use my front camera. Wiped phone clean and installed twice. I will wait till next rom.
sudo pand --nodetach --role PANU --search
There's a memory leak somewhere in the base CM7 code... this will be a BITCH to find, but it's there. The only fix is to reboot periodically at present; it's NOT in the applications you load, as if it were killing them would fix it - and it doesn't.
It's in the "base" CM7 code somewhere.... I've been able to reproduce it, but not find it as of yet. If you're running into very slow response on the rotation sensor or other apps, this is why....
I'm on it but this is NOT going to be fun to find at all, given that it's not my code or development in this issue.... the fastest fix for it is to reboot roughly daily.
Incidentally I've run a solid 8+ hour tether session, and it was utterly stable while running CoPilot the entire time. This ROM is, in the general sense, VERY stable and usable IMHO - far better than stock.
Is Koush and the CM team aware of the leak? Maybe they should fix it instead of you....
I've had the 10/2 for a while now and Ive experienced the known bugs, but today something new and potentially bad is happening. When i receive or make a call the call suddenly ends after 2 seconds. Ive rebooted, taken out the batt etc... but its still fhe same. Now, i shut down 3g and im able to receive and make calls..
Also, is the video driver Ok? My video is choppy on flash. Youtube is ok, but any flash video is not ok.
Thank you TG for your work.
First off thanks tickerguy and all others that have worked on this rom, its a great start!
I am experiencing alot of the bugs noted which still is usable as a daily IMHO. Let me know if you need more testers and any logs of anything for testing. I am willing to help.
Issue i am having is i try to tether to my galaxy pad over bluetooth. It connects and says i am using it as tethering but when I try browse the web i get a page can not be found error. Where can i look, log wise or other ways to help me understand whats going on here.
