DrakonVolk
TG, thanks a ton for all your hard work; I'll take cm7 with its current bugs over the stock rom any day! You rock, man.
Whenever i clicm on the phone it takes meto the call log instead of the dialer, anyone else having this issue??i?? I
The init scripts set the minimum CPU speed to 245k. I will look at this, but I'm concerned about changing it, as I've played with this in some other settings and have run into trouble below that speed with the phone either not waking or failing to answer hails from the network quickly enough (which results in a call going to voicemail instead of ringing!)
Someone mentioned an issue with the soft key lights? There isn't one - the behavior you're seeing is intentional - off when totally dark (or nearly so), on for low light, off for high light conditions. That's how I have it set - if you don't like it go modify it in the CM7 settings screen - I want the backlight on the keypad OFF in complete darkness; you may differ, but I use the phone as an alarm clock at night.
Haptic not being present on the keypad is something internal to CM7 and I haven't found it yet.
The front cam should not support zoom AT ALL. That it does is probably a config error - it's not supposed to as it has no zoom function (or focus function; it's a fixed-focus VGA resolution camera) in the hardware. The "digital zoom" (such as it is, when it works) is nothing more than blowing up pixel size and trashes quality, and thus shouldn't be enabled. I'm not surprised it blows up if you attempt it as I certainly didn't intend for it to work. I'll look at this as I'm doing a few other things with the front cam still; it's likely an error in the definitions for the front cam and should be turned off.
TIAPlease help...might have screw up my wife's triumph. Decided to install the final Alpha version to my wife's phone (I have done it to my phone for awhile).
I installed the recovery file image then did the cm7 update after formatting or resetting. When I restart the phone for the first time, it does not give me the initial setup (like the new phone)...in addition, no app market, automatically is booted with live wallpaper. it does give me the cm7 logo at boot. Where did I go wrong? I thought it would be a piece a cake since I did it to my phone so many timesTIA
I installed gapps the first time...I thought it was the reason for the screw up. Restarted the process with re format then re installed without it....same problem. Btw, I thought gapps was for google voice/video. Pardon my newbie...
I did the gapps after the rom install all the times...it works on my phone, except my wife's.
Thank you for your help!!! I had the wrong Gapps file...BTW, what the difference between the two?
The first one has everything- market, talk, setup wizard, search box, services etc.
The second one just has new version of talk and nothing else
I wiped /system the installed 10/12 but the front cam still crashes when you try to take a picture. Any ideas?
Same here. I waited before I posted on this so I could try everything to correct the issue but I still get FC. Definitely not a big deal because I never take pics with this cam. It does work for me with video chats. No problems there![]()
i know this is a lil off topic but would it be possible to do hdmi in(instead of out) on the triumph. i want to connect my devices that have hdmi onto it. i like to frankenstein my devices at times.
i know hdmi out is 720p and we have a 480p screen
