So I've been using the latest build since it came out and my battery life has been really bad. Today at work I only got about 4 or 5 hours of battery life and that's with wifi off and just having the phone in my pocket. I even had the governor at smartassv2 and gps off. When I checked the battery status/usage it showed the android system as the biggest hog. Any one else having this issue?
try opera mobile. Your browser isn't allowing zip downloads.Is anyone else having trouble downloading? I click on the link to save and it keeps downloading the htm instead of the zip.
Hey Isaac, if you push your changes to your github, I can build it and test the hdmi later if you want.
Yes. I hit some build errors, but I think I'm passed them now. I don't have a mini HDMI cable to test this out, but I'll get one I guess. We may actually have working HDMI on CM7. We'll see.
EDIT: Woot! It built. Will get a cable tomorrow and test if HDMI is working. I'll push the remaining stuff I have to my Github.
Yup... I noticed this with the 10/16 build... With everything turned off and barely using the phone I'm lucky to see 10 hours of battery. I hadn't said anything because I thought it was just me or something I did. About the only thing I haven't tried is a complete wipe and reload (I just formatted system and cache and left data alone so I wouldn't have to reload everything). I'm going to try a completely fresh install and see how things go.
One thing I did notice is that 10/16 is seemingly a heck of a lot faster. It even seems to boot faster...
What is the "official" unofficial word on the HDMI? i find it a handy thing sometimes, and was wondering if I could help test it out, if needed. Just let me know.It's already up. I pushed everything I changed last night. However, it's in pieces. The HDMI changes in frameworks is in an experimental branch and there are some changes to libhardware. Both of these will not get picked up by a simple repo sync and you'll have to cherry pick them.
I remember that earlier in the thread someone mentioned a popping sound in headphones when the screen is off - I've had this issue for a while, but it's finally annoyed me enough to ask if there's any sort of fix for it. I tried manipulating some settings in DSP manager, but I haven't found anything that works.
For the power widget, there is a color wheel and an alpha slider to change the color of the indicator "lights". Has no effect. Anyone else seeing this?
Im using "2x Battery" It allows me to shut data off when screen is off, however you can set the intervals to check for data every 1 minute, 5 minutes, etc....I have noticed a battery increase. I streamed Google Music for 2+ hours, and tethered for 4 hrs. and I was at 49%....No problems with battery life here, I have had mine on for 3 hours today, and it's still almost full.
Just reflashed cm7 from miui, and works great however the stock launcher is lagging. One person asked if anyone else is having this issue and all replied no, so I know it's not an issue with cm7. When I flashed cm7 I did a factory reset+wipe dalvic cache is there something else I was missing? It could be an app but I doubt it because I have very few apps installed and the ones I do have were backed up from my previous sessions with cm7 and miui. I will flash again, just want to know if I did something wrong on my end, or if I did everything right and just have to reflash. I am going to assume the responsibility
The notification bar power widget? Or the actual widget?
My notification bar color stuff changes correctly.
I get "stuttering" when I am playing music, haven't figured why, I have tried 2 different SD cards too
Check to ensure that "Lock Home in Memory" is disabled under Settings->CyanogenMod Settings->Performance
I believe that will help, but let us know!
