Root [ROM] CM7 TG-Reloaded (Final: 03-25)
I've noticed today that I'm getting reboots. At least four in the last three hours. Wasn't having this problem on earlier builds. Had this problem on two stock units. Yes, I wiped cache and Davlik and everything seemed to update fine.
Any ideas or anyone else having the reboots?
Redownload and try again, might have a corrupt copy. I haven't had reboots with this ROM since November sometime.
Ok the first few days I had this, the battery life was amazing. Now it is worse than the stock rom it seems to me.
The first night I had this, I forgot to plug my phone in before I went to sleep and I had my bluetooth on, my wifi on, my gps on.. pretty much anything that could be on was on. 8 hours later I wake up to my alarm going off by my feet, and I was like woh! I was expecting it to be at like 5% .. No, it was still up at 76%... Now after only a few hours my battery down in the 50s.. is there something that you suggest I do?
GPS and Bluetooth have been off for a few days now and problem is still persisting :/
Are you under volting? I had mine all set up, ran stability test over night, then later on it rebooted. Went to increadicontrol, hit +25 to all, haven't had a reboot sense. Also, look at you'd overclock as a possibles cause.
agree, battery is getting a lot worst than stock, application screen disappears, any chance to get a better stable version?
hey new member here, old lurker. lol. good work one the rom.
has anybody had any problems with the device not vibrating on incoming texts? and status bar force closing?
I have had only 1 time where I have not had a text vibrate, unless I wasn't paying attention, but I thought I was.
I did get a force close with the status bar once as well. But I have not had these be reoccurring problems for me
DenverNugs said:
Anyone having any issues with youtube force closing instantly upon opening it? Can't tell if it's a ROM issue or if it's just the app.
I have not been having this problem
I've not touched those settings from whatever the defaults are.
@ pbf98-I have found battery life is nothing short of amazing on 3g. I get over 16 hours with my normal use. On Wi-Fi however I can hardly last a regular work day. So if your device behaves the same as mine, I suggest you reserve wifi use for streaming applications.
On stock, I was lucky to get 16 hours of sparing use. Sense TG released beta .8 I have been getting WAY more use in my time. Now I get up to 24 hours with phone calls, browsing, and texting. If I download the latest release of a ROM, I use WiFi. And I still get a full days use.
Thank You devs.
Iaasic, TG, Mantera, Whyzor, and anyone else I didn't know who is involved.
Now on to a real responce. If you are having bad battery life, I'd recomend posting some notes on your personal usage. WIFI, good or bad signal, amount of calling, screen sleep policy... playing games or music. What ever. Just saying you get bat life doesn't do any good. Many are more than happy to help. It's a smart phone, like your car, if you use it, it will consume. I'd also recomend looking http://androidforums.com/motorola-triumph/461571-guide-triumphant-battery-tips.html>here to see some great tips for longer battery life.
Enough ranting for me, thank you and good night.:)
I have also been getting multiple random reboots on the latest 3-4 build, whereas before I got none.
I'm getting these reboots 1 - 2 times a day.
I've rolled back to 3/1; general instability (reboots) for me in BloonsTD4 (which I play too much) and a few reboots other places.
Getting the phone slowing down and freezing after about a day with it occasionally rebooting itself. If I have to turn it off the only way I can get it back up without constant reboots is turn off data, go to recovery, clear cache, reflashed, power off, let sit awhile and turn it back on. Seems excessive but this is the only combo I have gotten to work consistently. ROM works great afternoon that till it slows oe freezes again (randomly the last few days around 6 pm even. Coincidence I am sure but still crazy).
Okay, maybe it's not the ROM. Just random rebooted on 03-01. This is my second MT and both of them have had this problem. I effing hate this phone...may as well roll back to 03-04.
I stopped updating on the 3/01version. At this point every thing about my phone works perfectly the way I have it set up. It's amazing how smooth everything is. I have no real problems except for the un responding touch screen here and there. Now I'm just waiting for CM9 to get the camera working and I'll move there.
is there a way to restart the status bar besides rebooting the phone. Mine just forced closed .. and I dont like rebooting lol
Nope didnt work :/ .. well i rebooted it.
Every image i see of someone using cm7 I see 5 "shortcuts" on the application dock, mine however I only have 3 .. is that something extra that people do?
side question, is there an app that you can install that you can make folders in your app drawer? similar to Go Fx Launcher... I like the app drawer of it but want to keep the ginger bread look
