No need for SBF; I suggest you format system though (don't forget to mount system before applying your backup), and of course, wipe data and cache.
This morning I had an app that needed updating according to the notification bar. I went to the Market and the market must have updated as it required me to once again agree to terms.
Then all of my installed apps no longer appear in the Market app under "My Apps". The apps ARE installed, just not manageable or viewable from within the Market app.
Ideas?
happens to me sometimes. clear data for the market from within apps management and it should resolve it. happened on apex as well.
Can I go the other way without sbf to then, Bo?
Edit: my apologies for the wrong info, col.![]()
^^ I had market fc's too, fwiw.
I'm assuming you used the latest Gapps, maybe there is an issue with that. I haven't tried installing the latest Gapps as I haven't had any need to do so.
No Market FC's for me. Did you guys install a Market over a Market update (without removing Market updates)???
English?
So does anyone know how to kill this charging green led light. It's like having a laser beam shooting into my eyes while trying to go to sleep. Btw, I bought the hdmi dock on Amazon for $18
You might be able to turn it off by using the AdjBrightness app.
