Root [ROM] CM7 with GB kernel by RevNumbers
@Steven
How do you like my unkown caller id pic? :D
I also made it a bit bigger because it was kind of small for me (the incoming/outgoing call pic is larger for all calls, it just happens to be the unknown call png on the screenshot) ;)
Stock:
Enlarged:
lol!
Did it take you guys awhile to calibrate the battery? Charged phone to 100%, reset the battery info with the batterycalibration app. Let it drain to 0%, charged it back up to 100%. Was at about 60% an hour ago, now it's at 20% and I didn't use it in between.
Trying to install this now. I am currently running liquid 2.6 so I figured I would d/l the .602 all in one from tbh app. d/l finished and I made a back up of liquid (which took three tries to get a proper back-up through Rom Manager), and went into recovery to flash the .602 zip. The screen is now stuck at opening update package. What do?
I'm sure there is an easier way than this, but if I were you, I'd skip the .602 AIO altogether. Instead, do the .602 SBF, and root it with the new method... best way to start fresh IMO, but perhaps I'm just more OCD about it than others.
I ended up making the ISO burn disc with .602 SBF. I'll be going with that method. I had some free time at work so I tried doing it with the aio because I didn't have my computer with me.
Got this install just fine, but I have the weirdest issue. For some reason I can't get the "circle battery widget" to display properly. Anyone else having this issue?
This had been the best second init Rom for me so far. Went 12 hours only dropping 30% battery today and I get terrible battery life at work. Also, android overclock hates 2nd init roms that I've experienced, So I haven't used it.
Android OC has been working fine for me ;)
Can't seem to send MMS messages with this ROM. I've tried the stock messaging app and Handcent. It just says sending but never gets delivered. Any ideas?
It's a known issue, just read about it at rootzwiki
ahh wish I knew about that before yesterday lol I took my son to the zoo yesterday and couldn't get any good pictures because of it. Had I known about it then I would have flashed another ROM. Oh well. Got some good ones of the elephants. (no zoom required! Haha)
