it didnt fit tho. lol![]()
tee-heedoes if you get cm11 working lol
They've moved on to quiet riot now.
Any existing MMS fix for this latest build.
Edit: Nevermind. Just swapped the APN XML and it works now.
You did what to get MMS working??
I went into that the zip of the samurai ROM with root explorer, I forgot the exact folders but I believe its in the system/etc folder, extracted the apn.config.xml file to my sdcard, and simply swapped that file with the existing XML file in the rom. The XML in samurai should be smaller than the one in cm10.
PG I've been trying to build CM11, but AudioPolicyManagerBase.cpp always errors out. I checked on XDA and someone said to repo sync and it might be fixed in the source. I checked the repo instead, but that file hasn't been updated in 20 days.
Is it building for you?
Thanks for reply. I thought it was just me lol.nah it stops on display crap for me lol
So I guess I'll wait till source is updated so I can sync and see if it builds. Darn spirit lol.
Yours.which branch you using for the device repo?
Yours.![]()
Oh thought you saw it in my first post... cm-11.0which branch tho lol
edit:
Now I know what you mean with the Quiet Riot song lol.
Wait, I'm confused. Are you using a different branch I don't know about for cm11?yea I'd be surprised that would build cm atm lol
Wait, I'm confused. Are you using a different branch I don't know about for cm11?![]()
yeeModded YouTube app works with HD. With no picture..
