sk8rgeek
What difference does it makes?
I seen a few people having problems with Reboots...
Does going to gingeresteem fixes it?
All I know is mine is stable..I run benchmarks at 2GHz and I don't get reboots
anyone have any problems with MMS ? and can anyone advise how to fix the swipe fc's I updated the swipe cuz it asked to so maybe that's mistake? can I go back to the beta version that was orignally put on the rom? if so can somebody please give a brief explaniatin how to? Please///
I did the same by accident and I also get the FC's. After I close it it works ok for a bit then does it again when ever an app needs the keyboard.
Can someone please clarify how to boot in to CWM
Can someone please clarify how to boot in to CWM I thought that i was following the instructions correctly from playfulgods's post but i guess not?? Here is how i am doing it and failing:
Phone is ON.
I hold down the PWR and both volume UP and DOWN keys (3 buttons all together)
The Airplane Mode, Power Off, etc screen comes up.
I continue to hold the three buttons.
I release the buttons when the screen goes dark.
I press the power button 3 times when i see the LG logo.
I do this and it just shuts itself off and i get my battery charging screen (because its charging)
I installed the AIO root and CWM RC as instructed http://androidforums.com/roms-playfulgod/462079-cwm-rzr-root-aio-root-recovery-lg-esteem-ms910.html <--- there..... it attacked my phone with some zerglings (just like a zerg rush in starcraft 2 or 1) and it said successful after it rebooted my phone.
I do NOT see CWM in my applications list.
What am i doing wrong?
Thanks in advance for any help!
Phone is ON.
You want the phone completely off. Press and hold the volume keys then press and hold the power key till it vibrates. When it vibrates let go of the power button and continue to hold the volume keys. You will then go to a black screen with white letters. Disregard anything that screen says and just hit the power button 3 times. Then the phone will reboot again and youll be in cwr
I used quick boot. No problem.
+1^^^^ yup, i just used this. i have never done those power+vol combo method, so yeah. Simply download quick boot, open it and select recovery. That will take you to recovery directly!
Really not that hard, I must admit it does seem unnecessarily complicated but I'm sure the devs have a reason.Amazing ROM, haven't gone above 1.6 but that's more than enough for me. Only complaint I have is the theme and I can't seem to change it without some part of it still being there. Guess I'll have to go back to 1.0 and just flash the kernel.
or you could cook for yourself at the kitchen![]()
Anyone else get a similar issue?
Am I the only one that has the recovery option in my power off menu? Im just curious as to why everyone is using Quick boot or other apps when you can just hold the power button for 2 secs then select recovery.
You know I just followed Shiny's ghetto ass tutorial on another thread xD and I could only get the window animations to change with my zip. I included the power buttons too but only the animations did.Anyone else get a similar issue?
I'm hardcore loldidn't notice the rom even had one haha.
