nitestalkr
And not to mention that it is always good to regularly check if a backed up app that is not currently installed, has an update available. Checking maybe once a week, or once every couple of weeks is usually a good idea.
You should look into the multirom by bigsupersquid and tasadir.I just hope that there isnt a Quattrimus update tonight or tomorrow, i would go crazy bouncing back and forth, backing up and restoring backing up and restoring... and testing out all the features of both ROMs and reporting back any bugs.![]()
*bigsupersquid and tasssadarYou should look into the multirom by Whyzor and tasadir.
Edit- I think both kernels have to be the same on multirom.![]()
New build is up:
-More fixes for screen freezes caused by ICS rotation animation
Running great for me as well this morning. Upgraded from the prior build, and no frozen screen yet.Running great on my V. Thanks for the work!
Spoke too soon. Picked up phone and screen was frozen. Felt haptic feedback, so went through motions of unlocking and rotating screen to fix.Upgraded from the prior build, and no frozen screen
Did a fresh wipe of everything and installed the new build and green theme again. We'll see how she does now, I'll update my experience after running for awhile. Seems great thus far, just got done resetting up my Link2SD and restoring my apps with TB. An easy to follow guide by benslgdroid on that matter is located here for those that may be interested.Spoke too soon. Picked up phone and screen was frozen. Felt haptic feedback, so went through motions of unlocking and rotating screen to fix.
Disabled ICS animations and will try a full wipe tonight after work before declaring it is an issue.![]()
My screen continues to freeze if auto-rotation is enabled, even with yesterday's build.
For the record, upgraded to 0219 from 0212. Runs smooth as always but this afternoon I was jamming PowerAmp while doing housework, and the lockscreen froze up. I had to do a battery pull!
Don't know how much is the rotation bug (I still have it, just haven't said anything) and how much is PowerAmp. Version 1.4 was great, version 2.0 has awesome features but is a little buggy on BACKside. It always has been, but this was different. It was the first time I had to pull the battery. I'll try to replicate the problem tomorrow while doing dishes, and post my findings.
See above post.My screen continues to freeze if auto-rotation is enabled, even with yesterday's build.
I included the ability to keep screen rotations, but disable the ICS rotation animation. Please test with rotations on but ICS animation off as well.
Settings>>CyanogenMod settings>>Display settings>>ICS rotation animation
(uncheck and reboot)![]()
Also the scrolling screen brightness=No go, is not even highlighted in CyanogenMod settings(the option is there, it's just not selectable). Could this be caused by a theme?
 )...and then click on the images tab.I've become obsessed with changing the notification dropdown. Google (any topic) 320x480.
