It's an issue with the ICS rotation animations. I added an option in the last build to disable them.
Settings>>CyanogenMod settings>>Display>>ICS rotation animations
(uncheck it)
Diane Hackborn from the AOSP team has another fix in CM's tree, I'll be trying it out in this weeks build.
Was going to mention about this as well.....Thanks Jerry for the latest update. I think the 'Skip on security' function may be partially broken--under Settings > CyanogenMod settings > Lockscreen > Unlock options. I've always had this option checked/selected, and the setting would be retained and functional after the last several updates. However, in this latest 0229 update, the function no longer seem to work after a reboot--the Sliding Tab lockscreen appears even though disabled. Attempts to de-select that 'Skip on security' option would also not stick. Please check when you get a chance. Not a big deal, nor a show-stopper. Thanks again.
[Edit] Besides upon reboot, the Sliding Tab lockscreen also appears unexpectedly when the charger is first connected. [/Edit]
Running into the same thing with the rotation animations. Unfortunately that still doesn't appear to be fixed. Too bad, those animations are really nice.Jerry: Looks like the issue has persisted with the 20120229 release. I reenabled ICS rotation animations and the screen comes back on frozen with the last screen I was on instead of the unlock screen.
I use Widgetlocker to lock my phone. All the other builds I used so far I had no problem disabling the CyanogenMod lockscreen. With this build when I slide my slider on the Widgetlocker, which then went to my number pad for my passcode, now goes to the CyanogenMod lockscreen. Then when I slide that, it goes to the number pad.
Before I think I went into the CyanogenMod settings and clicked disable when password is used, but it does not appear to be working correctly in this build.
[FONT="]Other small issue I have noticed, I use my Blue Marble theme, I noticed that the cell strength symbol is not the correct one at certain times. I did recook the theme in the Kitchen and have not flashed it yet to see if it was a Kitchen glitch or flashing glitch
I just went back and cooked the theme again. Just realized I had selected the wrong icon pack.I had the same problem using those icons in the past on two different v's. I think that icon pack is just flawed somehow and can't work correctly with our phone
You either had a bad download (did you use the BacksideUpdater? it checks the download automatically, if not you have to check the md5sum), or you didn't wipe cache/dalvik-cache, or you had a bad flash.
Redownload, check the md5sum once it's on your phone, then reboot into recovery, wipe cache and dalvik-cache (under advanced), then flash the ROM zip file, then reboot.
To check the md5sum, open the BacksideUpdater (in your app drawer), wait for it to load the manifest, then press the menu key and select "Already download - Select File Manually", then choose the ROM zip file.
or
Open terminal emulator and type the following:
Code:su md5sum /sdcard/download/BACKside-IHO-VM670-02292012.zip
yeah, everything's still on the card. I rebooted into recovery and tried to mount from there and got the following message: "Error mounting /sdcard!" After searching, I found a link to the LG drivers to fix the USB connectivity issue, but I can't install them without an SD card. Maybe a hardware failure?
We don't discuss borderline unethical actions in here.anyone tested a Best Buy warranty with a rooted phone?
Seems to be working fine now:Anyone have a mirror link to the gapps? Site is down right now. -_-
Thanks for the suggestion...but no such luck. When I tried to erase it, I got a message that said "SD card has been removed."
Go here http://androidforums.com/optimus-v-...guide-100-stock-lg-optimus-v.html#post3565591 Put Stock ROM, and Recovery on phone. Unroot. Then you must decide if you want to do the next option:anyone tested a Best Buy warranty with a rooted phone?
