Hi,
I'm using the ClockworkMod recovery and was thinking about changing to Jerry's suggestion. I've searched this thread to find out how to change recoveries but don't see anything. Does anyone have any suggestions? Do I simply flash the new recovery?
Thank you!
Hi,
Thank you!
Okay so what do I do with the particle boot file after it's done downloading? How do I apply it?
Read the instructions in the post right before you......
But I'm not trying to install the recovery. I did that already, I'm talking about the boot animation. Do I flash it? Use prompt?
Dalvik improvements... New recovery with auto updater... Constantly updating...
I'm always trying out other ROMs but I always come back...
:adore: <---me
*Edit*
Any way to get the recovery to be red? >.<
He said he was going to be making it customizable. Patience young grass hopper.
Whenever you do a rom update, and see link 2 sd not working. Don't panic, your apps are still there. Only the apps that were moved as a system app will be gone.
(If you even chose to do that. For example I had go launcher moved as a system app instead of being linked as its a launcher. I also wanted the system to accept it as part of the system, mainly because I saw a performance increase compared to just leaving it on there as a standard app.)
I have always done the following:
open link 2 sd. Disable auto link for new installed apps, disable the link at boot option. Restart the rom several times. After 3 or 4 restarts of the rom, open link 2 sd back up. Recheck all your settings. Then restart again. If you are still getting mount errors or any other error, recreate mount scripts. If you get an error, try going through choosing different file systems
(ext, fat32) until you get the message that link 2 sd will create the mount script at boot and prompt you to restart. After doing the recreate mount scripts, do a quick reboot. It might take a very very long time. It took mine 10 minutes before It booted up. After it boots, let it sit some more at the home screen. Restart the entire phone again at least a couple more times. You should now be fine.
That's the entire process I did to make everything work again after the rom update.
I would also suggest after everything is working properly, to go into link 2 sd and clean up the 2nd partition as well as dalvic cache, clear all app caches, and last but not least link dalvik cache files. Then choose the refresh option and reboot. Should also gain some more space that way.
Thanks for such a detailed explanation! I'll try it. Perhaps I'm not patient enough to let the boot completely finish.
Please let me know how that process works for you.
Here is a tip, while its booting, make coffee or play 2 rounds of modern warfare 3. haha. Then when you check on it again it should be booted.
Sure enough. It worked. I think changing the settings in link2sd may have done the trick. I've never tried those settings before.
I haven't tried MW3 yet. I'm currently playing through the Battlefield series.
No, but slightly less, yes.Is it normal for this ROM to have significantly less battery life than Harmonia?
You cannot determine your battery life till you have been running a ROM for at least 3 days. The day you install it, you eat a lot of battery with the install process, and with checking everything out to be sure it works. Then, it will take the battery stats a few days to average out.
You might want to go into recovery, wipe battery stats, then give it a three day trial to see how much juice you use.
Google betterbatterystats (one word) for possibly the best app for determining what is eating your battery.
I get a full day (20-27hrs avg) on BACKside-IHO with moderate usage, and so do most other people.
I never have wiped my battery stats, is this something you need to do from time to time?
