Edited the post but in settings GPS antenna click internal and it will lock in fine.
Guess I'll flash from D since it still doesn't work for me
You are foolish to think that an app can't go on your phone sorry that you seem to think in the box but its on my lg motion and I don't get any app from the play store other than say ten apps I put on every phone I ever have and only one was worth paying for - Klink its a tether app that's the best out there
I did that too but still nothing.
tried going outside?? lol
Dude, there's like bugs and stuff out there. I don't want to die.
Pg latest {517} build for me has the echo still, I flashed from i different cm build so that could be it. I realized cm doesn't do talk and data the same time like the stock rom does. wifi works bluetooth sharing works as well camera crashes while recording (changing the zoom 1080p only) no issuse with call volume, other phone comes in crisp and clear to me but my phones sends out a echoy static filled sound
Flash from stock D
Its getting 4g speeds, its just saying 1x on the status bar
bt its still in 1x coverage
No, it's 4g coverage, with a display bug
But actually its not, the CDMA radio is connected to 1xRTT, that's what those signal bars are for and that is the reason it shows 1x. The lte radio is connected (if you're in a coverage area) but it is not reflected on those bars at all,its happening as a background process,as far as the os knows its connected to 1x for voice and text and the lte connection is just a normal network connection.
This is for sprint but the same applies here,its an android issue not a carrier issue.
On most phones the os at least correctly shows that it is connected to lte,but those signal bars still show 1x signal strength. Ours doesn't show the lte logo because of how pieced together our ril implementation is.
Flash from stock D
nvm i got the torrent link to work finallyi cant find a working link to download the kdz for stock d
Phone volume low on bobz cm 10 build April 28
thats what his thread is for!!!
I have a new build posted there as well.![]()
Found my every-day rom! Just one question; Anyone know where to copy the obb files for a game to from my backed up data (from before I flashed CM)? I tried Shadowgun deadzone and it works great, but they want me to start from level 1 without my old user obb data file. I was on like level 14, and would hate to have to start over again! I can't quite fully understand the sd card format yet. There's an "sd card", then there's "external sd" then there's "mnt", which also has an internal/external sd file within it. So which one is it? Which is the main file extension that CM uses to read data from the (truly internal) sd card? Or even worse: am I screwed since there was a transition from ics to jb? I guess it wold be a small price to pay for jb, but if there's a way to copy the obb file successfully and pick up where I left off in the game, that would be ideal.
