0utSid3r
Just flashed 517 from stock F firmware, No echo. Have not tested everything but all seems good less the known 1080p and 4g icon but I don't need that.
Thanks for all the hard work![]()
So it does work on version f?
I'm on Mini Motion F (basically a debloated f rom) should I go to a certain firmware before flashing this rom?
Will u post link for mini f rom?
So it does work on version f?![]()
It did for me, I was running Stock F Rooted, I downloaded D just in-case it had issues but it runs great flashed over F.
Wifi too?![]()
You guys claim its 4g but i don't think so right now im downloading an app and its slower than ever its usually not this slow.![]()
I swear I'm in the same part of my house as i usually am and I always get 4g(all over my house regardless).Your probably actually on 1x![]()
i've been messing with a file labeled voice_call in /system/etc/snd_soc_msm i made a bunch of changes at once (not a good idea) and whatever i did made it so all i get is a busy signal, but i can hear it at arms length and i have long arms.
i have 4g but only says 1x.
@playG, Binding both internal and external remeoves i believe sd_0 or sd_1. also i have a sd card with 32gbs + 5gbs internal = amazing over 200+apps with alot of games/data.
@Xt51 its in root/system/hw/lib and find the file and move or delete your fate.lol
Im in love with this rom. i hope pg and all can help beergang rom. or at least have tablet ui with this
i know how to get stock 4g speeds but i ain't tellin :aetsch:
Any luck with tinkering with this? And what did you change?
Hey guys, haven't been on in a while, been building on the CM10.1 on my own
Well, I think I will be getting a Nexus 4 so, I won't be able to work on this for much longer, which sucks, because I could still build, but not test as many things, well I wish you the best of luck with this guys, and don't forget to appreciate your devs![]()
just hold on to your motion.
Not like its gonna bring alot anyhow.![]()
I might just sell it or give it away to a more experienced dev so they can do a better work than me
