Where is this !Flash version c modem![]()
Where is this !![]()
Why are you removing the lights.msm8960???
Is there an APK for the Vu2 recovery used in PGs 5-17 cm10?
Pictures aren't sending on pg's latest build. Not sure if it's just me. :c
You're right, but I was just wondering if there was an updated APK like lte2recovery.apk that installs 6.0.2.7 for you
I came from d and music player freaked out. PlAyed garbled sounds then rebooted. Seems to be playing OK since reboot though I was scared to mess with bit while it was playing.
he's got an apk in the spirit forum that uses 6.0.3.1 touch recovery but it's oversized on lg motion and is hard to navigate.
but it does work
edit put me in a boot loop
edit when i extracted the recovery tar and placed it in /system/xbin it worked fine with no bootloop
i got touch recovery![]()
apollo works fine for me. no lagg or anything.
Sorry, I didn't clarify. I just want to use the sideload feature from stock after I unbrick since I find myself bricking a lot. Sorry for the confusion.
cyanogen mod
Stock rom
