Root [ROM][WIP] CyanogenMod 7 | Android 2.3.5 (Gingerbread) | Current Version: 09122011
ohh fashoo, so iss coo if i update my cm7 then right?
depends on which build u have, if you have the build from the 23rd then you will have top start from scratch. But if you have the build from last night (30th) and flash the newest build when he gets it uploaded u should be good.
I'm sure he'll update us when n what when he gets it ready.
yea i got from 23, so i know i gotta delete, i am gonna do the 30th right now, i was jus askin i wudnt have to clear everything for update tonight after i get the 30th on it
ohh yeaaa i got the 30th version, camra works sweeeet, yee now this is bout 90% perfect rom maynn, supper fast
once again thanks isaac for taking your time into doing this!
hey one last question
i have completly flashed it and works perfect
the ZIPPED file i put on sd card for cm7 03302011.zip and google apps.zip that on sd card, can i delete those? they are like 90mb total..will it affect anything?
yeah i been running cm7, love the rom, lolz wanted to try this cm6 for a while. but cm6 also runs a little smoother than cm7 but i like em both.
I would just have to flash the zip or is there more to it for cm6?? I'd like to look at it just so I can answer ?'s about it lol
what idid was a wipe of everything to give it a fresh start, than i backup cm6 like i did cm7 and icarus. so when i get ready to load a rom i just go to cwm and flash whatever back i want no more wiping.
yea tats wut I just did with cm7, cm6 booting now n once I get it all setup I will back it up too lol.
What sux is I think I poof'd my backup of 2.1 when I formatted my sd card earlier lol
i did the same with backup 2.1 but i got my recovery stock script handy:D:D:D
did you d/l both files....and did you use cwm 3xxxx or 2xxxx
check pm please~~~
I used cwm 3 and I downloaded the cm6 zip n gapps zip n installed both of those.
In toks howto he said to format so lol, I'm gonna see if I have another sd card big enough to use. If not oh well, I just wanted to have a look see anyhow. I have it up n running n sync'd with google.
remember to format boot,system,cache, data, but i never did format my memory card, just put the 2 zip files on my sd and rebooted into recover and wipe data and all even delvic
I have a question. Since MMS is not working yet can you still receive longer text messages? You know how sometimes as you are typing a text message and after so many charectors it says converting to MMS. Will we still be able to send and receive these longer text messages?
Thanks,
An update on the current situation. As I stated in my post above, I'm working on USB and WIFI hotspot.
I've managed to get the menus enabled, but the functions don't work. I've been reading that I would need to enable this support in the driver, but I don't have the source for that. I'm trying another build that kind of hacks into place and hopefully it'll work. I'm not too concerned about USB tethering.
Good news is that the overall performance seems to be up. I was able to play Angry Birds (with the background off) and it was smooth.
The electron beam animation won't work. I thought maybe it would render the animation without HW support, but it would seem it doesn't. The Ascend is probably one of the only phones that DOESN'T have a dedicated GPU. Hell, even the original MT3G does. A crappy one is better than nothing at all.
I have the Optimus V and while the Ascend does run Gingerbread fairly well, it's really becoming apparent that 2.3 was never meant to be on the phone. Most of my goals for the Ascend have been met. I wanted to get a mostly functional port of 2.3 on the Ascend and I think I have.
