lpequero@gmail
ok so i flashed the metro off and i still cant send mms
)I'm having issues with the new GAPPS downloading things from the market. They say they will download, start to download, then stop and disappear. Some apps can be downloaded, some can't. Tried using Appbrain to send them to my phone, doesn't work with the specific apps either. If I flash a previous version of the Market/Gapps, with that corrupt something? I'd rather not flash the ROM all over again. - Thanks
new gapps work, but you can flash 03072011...
check the kmod thread, may change your mindlol well im on the kmod rom right now ill wait and see for next rom![]()
Waiting
Hey guys in running Cm7 on huwaei ascend and it randomly will start making a noise its says when i turn it up and down on the volume rocker it says in-call volume and i have to call somebody and hang up JUST TO FIX IT LIKE WTK?!!!! PLZ OF DEAR GOD TELL ME HOW TO STOP THE STUPID THING!!!! FROM MAKING THE NOISE ( before i went to cm7 i was 2.2.1 AKA Tapout edition)
Oh, by the way, I love CM7, thank you to everyone involved with its builds. And I did also try calling the phone to knock it out of boot loop, did not work :-(
I think its just the rom and can you give me cm7.1 plz
yes it is the phone its a known issue with the ascend or it might just be cricket as most of the forums i have seen reporting the same issue have been on cricket...its only a temporary problem that is easy to fix but for now no one has come up with permanent solution...mine started doing it when the phone was stock and same with my wifes...hers has done it 3 times since she bought the phone and mine twice with and without a custom rom
