Root [ROM][WIP] CyanogenMod 7 | Android 2.3.5 (Gingerbread) | Current Version: 09122011
seems as tho you have a lazy ascend, try reflashing making sure you wipe and format everything except sdcard, and also you have to format and partition your sdcard if you are installing the latest build.
page is down, but you can always go threw rom manager and download gapps and cm7.
i formatted sd card it still wont leave this screen can some one give me a link to a good cm7? maybe my download was bad or maybe the correct steps?
I am going through ROM manager and trying to find older versions of CM7, to see if i can get my ringtones to work, even when i select system ringtones, it still only plays the default through the phone/setting menu.
i have that update it still wont pass the orange screen what do i set my sd at when i partition it ?
so do i use the same gapp and mms fix for this update?
sorry for the bother but this is really frustrating ty so much for the help
if you installing the latest cm7 partition sd card threw recovery and choose 512 and 32 for swap, make sure you have a card reader cause when you format and partition the sd card it will erase everything. make a backup of your sd card also before attempting this.
it has made it to the cyanogenmod load screen hopin for the best ty so very much for all the help lets hope this works :)
Well i would just love a CM7 that i could have my individual ringtones on, everything else works great, and i love the project, just not being able to have my ringtones is a bummer
that sucks...:D but hey faster rom with a little flaw. ;)
If you could supply a bit more information(CARRIER,CURRENT O/S),& any other info that you think could be helpful & someone here will jump in & get you running smooth again.
sorry lol MetroPCS Huawei "lazy" Ascend CM7.2 by PlayfulGod also decrease boot loading time
1) If you have a CLASS 4 or lower SDcard,move the DALVIK CACHE back to internal memory.
2) Try out the app STARTUP AUDITOR to help out w/boot times.The decrease in boot time will be marginal at best,but,this app will keep some user apps from coming online unprompted.
Also,considering you have a 'lazy' ASCEND,boot times aren't gonna be lightning quick.Neither are average or above average ASCENDS either.
The CPU in this phone is overtaxed as it is,so,boot times aren't gonna be anything like,say,a DROID X,EVO 3D,G2X,etc.....
Best thing you can do after installing CM7 is getting a CLASS 6 or better SDcard.
I've noticed a dramatic performance increase since getting a CLASS 10 for my phone.
your welcome...
i went and bought new ascend from metro running the 2.2.2 it caame this way my old one was 2.1 i got a new one so i could back it up right this time to be able to go back to stock do you have a good free rooting link so i can do it right this time?
when will the newer build come out?
I wouldn't ask any developer that,it's a sure-fire way to p*** them off & to discourage further development.
If you look at the DROID TIPS when first flashing a new ROM,I believe it's tip #2,don't ask for ETA's on updates.
use GingerBreak ;)
