Just rooted my EVO thanks to this guide. Previously had a Hero that was rooted. I'm looking for a good stable ROM for my EVO. Any suggestions as there seems to be a lot of ROMs?
MikG 3.0 is the rom of choice right now. That may change as soon as they get the ICS roms stable and everything working but Mik won't be to long to get one of those out as well I don't think.
+1 on MikG.
And aww, look at the little guide go! He's all growed up.![]()
Congrats on being green xtreme, well deserved.![]()
Do you have to flash anything else with the ROMs on EVO, like gapps?
So I am rooted and running MikG's 3.0 ROM.
THANKS EVERYONE!
My HBoot version is still 0.79.0000
I used unrevoked v 3.32 to root. It uses ClockworkMod 2.6.0.1. I thought it used an older version of SuperUser, but I now see it is version 3.0.7 so maybe it updated itself.
My WiMax keys made it and I have backed them up using an XDA Developer method which uses ADB, but I have no clue how to restore them if I shoould ever need to do so. I think the newer versions of ClockworkMod or Amon Ra will back them up as part of backing up an installed ROM.
My radio is still the same: baseband version 2.05.00.06.10
So my questions are: should I try to update my bootlet (which I think is not the engineering bootlet (as that is 0.79.0000))?
Should I try to update ClockworkMod (or change to Amon RA)?
Should I try to update my radio?
Revolutionary will not find my EVO?
Followed all steps exactly as listed and still says waiting for device.
I have rooted 2 other EVO's all identical and no issues untill now.
Please help
USB debugging was the culprit. thank you very very much
I've been reading this & other forums & watching lots you tube videos on rooting. I'm finally ready to root my evo. The only thing is how do i save all my contacts, pics, music, apps etc. before doing a factory reset? also is revolutionary the best root or is unrevoked? just not comportable with giving out ssn#.
hboot is 2.16, i just hit recovery now i have a red triangle wit an !. what did i do wrong?
thanks
Did you try rerooting with revolutanry?? not saying you should because we have no idea if it will bork the phone but if you did try i was wondering what happened. did it tell you the hboot was wrong or not reconise the phone or any thing like that? I dont recomend you try but if you already did i would like to know what happened.***WARNING*** CURRENT ROOTED USERS, DO NOT UNROOT AND APPLY THE OTA UPDATE...
Well I made a dumb move and unrooted and then applied the OTA update. Part of the OTA update included updating my HBOOT was to 2.18.0001, and now I can't "re-root" using Revolutionary. DOH !! Needless to say, I found out the hard way what unrooting and applying an OTA update can do to one's future rooting ability.
Can anyone guess how long it will take the Revolutionary Team to crack the newest HBOOT (2.18.0001), and re-enable ROOT for myself and anyone else who grabbed this latest update?
welcome to the forums!!!!!!!!!!!!***WARNING*** CURRENT ROOTED USERS, DO NOT UNROOT AND APPLY THE OTA UPDATE...
if it does not work then i would go to their IRC chat that is linked in their wiki and ask the team about the new hboot and if they have plans on trying to gain root.
