i use amon ra recovery that i got from the Switching Recoveries portion of the Gingerbread version of rooting for dummies, it is the only recovery I can speak of. http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
In it though, once you have set your phone up in a rom the way you want it, you make a backup, a nandroid, and it does all that you are asking for.
CWM backups prob do the same, and I made one initialy when i rooted, but I have never restored it to see,
Will I lose root if I upgrade to Gingerbread? If yes, then I'll keep the Froyo. And, if I don't upgrade, will Amon RA work with Froyo? Is Amon RA another custom Recovery or separate -- I really don't want to replace the Clockworkmod that was installed with UnrEVOked. Thanks to all of you for both your patience and your help.
At this point I'm reluctant to swtch custom recoveries. I'm too new to this and don't want to screw things up (and brick my phone), so I'm being very cautious. The installed Clockworkmod is 2.6.0.0.1 (Not 100% sure of what follows the 2.6). I've used it to backup the phone. Will it do essentially what Amon RA would do in that regad? Can I use it to backup just the WiMax key and, if so, how? Thanks again to everyone.
Hi everyone,
I am reading all these posts and guides and one question remains:
Is it possible to root the new Sprint HTC EVO 4G 2.3.3 (not upgraded Gingerbread) (2.3.3 came pre-installed)? I found one website that says its possible but you must give ur Serial Number and obtain a Key or something like that...
Thanks
Nandroid backup? Uh (this after all is "rooting for dummies" ;-) ), is that the same as nano backup as in the Guide?
And again...
One more thing (at least for now), now that my phone is rooted, how do I get rid of (permaently unnstall) the pre-installed system apps that came with the phone and I don't want such as games, etc.?
lol yes they are the same thing.
just be careful on what you delete. i would get titanium backup and just freeze the apps you do not want at first before uninstalling them.
When I've looked at the apps under Applications > Manage Applications all that are listed are mostly those I've installed, but few if any of the one's that came on the phone. When I've used Root Exporer I often can't tell from the names what I'm looking at. They appear to be listed by their package names rather than the labels displayed under All Applications.
I will give Titanium a try (I've already got MyBackup Pro, which expanded to include some more tools and options once the phone was rooted).
As for Gingerbread -- where do I look for the best, most bug free Roms? Again, I'm really new at this (and here, after some 20 odd years of professional experience, I thought I was a technology expert -- goes to show you where pride can lead),
Thanks.
I had a quick question. I flashed the green lightning ROM which XD said he would try. I did a nandroid backup before. I played with the ROM a little bit but I just like the MikG better. When I restored it many of the settings I had before were gone and a few new things showed up when i did a restore. Some new aspect which were associated with thr 3d ROM. Now i wanted to do another restore but whrni went into the restore I get this error: oops something went wrong! Please check recovery log! I did a cache and delvik wipe and tried to restore again but same error. Any advice please? Thanks
try wiping dalvik cache and cache and restore your nandroid backup.
I already tried that. I did mention that in the previous post. Should i wipe the entire phone clean with superwipe and then try restoring again?
oops i cant read i guess.
yep that is a good idea. if that does not work and you get the oops again then in recovery select advanced and then select move recovery logs to sd. then go into your card with a file manager and then find the log. read through the log. it might tell you what happened. if you do not understand the log then go ahead and post it here.
