All Document Viewer PDF Reader
Document reader-PDF reader is docx viewer and offline reader to view word documents and read word doc of all file formats. All file viewer app makes it easy to view documents on a single platform for reading documents.
PDF word files, PPT presentations, excel sheets are most commonly used office files, all document reader app & all file reader lets you to open docs and view word documents in your phone to read and share word documents.
No need of document search for viewing particular file format for reading documents, all file viewer app provides separated file format folders of PDF files, word files, PPT slides etc. All document viewer & all file reader without wasting time easily search specific PDF files or view word document.
All Document reader-PDF reader benefits users for reading documents in an app with following features:
All document viewer supports multiple document formats; word, excel, PPT etc to read.
Document reader and viewer show your phone storage occupied by the documents and free storage.
Documents app serves as all-in-one file viewer; PDF viewer, excel viewer, docs reader, text viewer, and PPT viewer with fast document performance.
Doc reader & PPT viewer has simple user interface, quite easy to view document and read word documents on all document viewer pdf reader.
All Document Reader
All document viewer easily open word documents, PDF word files, PPT slides, word excel spreadsheet and make them readable. Best doc reader open word document and further clarifies reading by zoom in and zoom out the documents.
Manage Documents
All document viewer manages all office file to view and read word documents. Document reader manage documents by renaming the file name, that makes it easy to search word excel and PDF word files to read word doc.
You can delete the word documents, PDF files etc that saves the phone storage. All file reader easily searches the required files and share word documents files with others.
Documents Folders
Document reader examines the word document files folder in your phone and opens them for viewing and reading documents. Document app is quite convenient to easily access and open word document present in the folders.
All File Reader
All document reader makes available the entire documents files of all file format; PDF word files, word excel sheets, PPT slides presentations etc present in your phone to read word document. For viewing and reading documents of all format, doc reader enables you to view word document and then reading documents.
Make Favorite Documents
All file reader view documents and add in the list of favorite documents. Documents in the favorite file are easy to open docs, view and read word document. You can add most commonly used office documents, school documents or team documents in your favorite list that enable fast opening of the required documents.
Download all PDF reader
Getting to know my new tablet
Hi,
I have written at length, and often, after starting to come to terms with my new A8 tablet. I thank all who have kindly responded with advice and information; I am now over the initial teething troubles and enjoying the rather different features of thus tablet.
I hope I won't need to bother you all again, but it is good know you are there and willing to helpi
Thanks very much
Roger
Please bother us, please.. Come now. Just stay in contact with us!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
migrate android apps to ios
Isn't it possible to transfer data from Android to iOS when you set it up? I think there is such a function there, or am I wrong?
There is an option to transfer some applications and limited user data between devices, but that depends upon the application in question already being available (and free) in the App Store / Play Store.
It sounds to me like @dostoyevski was looking for a way to port an application from Android to iOS (where it doesn't already exist).
There are cross-platform development kits which can be used to produce (basic) apps which will run on both iOS and Android (spitting out a separate build for each but based on the same common code) but I'm not aware of anything which can easily convert an existing app (not written using one of those cross-platform frameworks).
Help Crackling speaker sound
Just use another browser.
First of all, Chrome is garbage at best- and nefarious spyware at its worst.
Use any browser that uses Android System Webview as the webview, and be sure to check the webview setting in developers options- Google has a nasty habit of making Chrome the webview!
(In my mind that means that Google is using Chrome to monitor everything you do online.)
Sometimes Chrome must be disabled in order for you to be able to change the webview app, and this also leads me to not trust Chrome or Google even more.
Lightning is an excellent browser, much faster and able to be more secure.
You can access Translate from the Google homepage, there is no need for any extra app at all.
https://f-droid.org/en/packages/acr.browser.lightning/
‍♂️ I got used to it. Password manager is a big go for me there.
LG is all done with phones...
My first Android was a garbage-tier Coby Kyros tablet that ran 2.1. Then an LG Optimus V that ran 2.2. I learned to root/ROM at least.
I do wish I had the funds then to enjoy real good phones like the Xperia Play, Kyocera Echo, O.G. Droids, and so on. Didn't get my first flagship until the Galaxy SIII was already a year old. At least I can enjoy the Thunderbolt and SII today however.
Cannot download to the specified location
Y
I gave it permission to use storage. Now it claims it's downloading, but if a file says 0 bytes, isn't it useless? I just moved some more to sd in order to make room. Can I PLEASE save directly to sd?
You do not want to save directly to SD cards.
If the file is corrupt, then you have wasted two read/write cycles of that card.
(One to save it, and another to delete it.)
This is why you should save to internal, look over the file(s), make sure they are complete and wanted, and then copy them to the SD.
Then, to be really safe, double check the file(s) that you just copied to the card for errors and whatnot.
Only after this verification should the file(s) in internal memory be deleted.
I am most guilty of just moving files instead of copying them.
I will admit that the success rate is very high, but there is always that one file that will get away- corrupted during the move and now lost forever.
Should you close unused apps?
I don't trust open tabs in a browser, since sites that you visit can scan your bookmarks (if your bookmarks have an icon denoting the site, then yes) and possibly even see browsing history and more.
The browsers I use all have a setting that allows the closing of all tabs and then the browser with a single long press of the back button on the navigation button.
Cookies, history, and web storage can all be set to be deleted at this time as well.
Turning off the screen has become irritating
I would have never guessed this in a lifetime!
None of the options in "Default assistant app" were selected, so I selected one called "Nothing", and the balloon is gone!
Thanks for the great advice puppykickr!
Glad to help.
Your issue was my issue as well a few years back.
I actually discovered this setting by using the Greenify app, otherwise I might not ever have figured it out.
Taker Permisison Error
Hello All,
Device: Samsung Galaxy Note 20 Ultra 5G running Android version 12 with Samsung One UI Version: 4.1; Tasker version 5.15.14
Can someone explain why I am now getting the following errors and how to resolve them. I have already given Tasker permission and still getting the error messages. Even when I check the option "Continue after error" the errors still occur.
How Do I Get Rid Of Duplicate Numbers From The ContactsContract
Here is a quick solution i came up with to remove duplicates
ContentResolver contentResolver = getContentResolver();
Cursor cursor = contentResolver.query(ContactsContract.CommonDataKinds.Phone.CONTENT_URI,
null,
null,
null,
ContactsContract.CommonDataKinds.Phone.DISPLAY_NAME + " ASC ");
contactArray = new ArrayList<>();
String tempId = "";
if(cursor != null && cursor.getCount() > 0){
while(cursor.moveToNext())
String contact_id = cursor.getString(cursor.getColumnIndex(ContactsContract.CommonDataKinds.Phone.CONTACT_ID));
if(!tempId.equals(contact_id)){
String contact_name = cursor.getString(cursor.getColumnIndex(ContactsContract.CommonDataKinds.Phone.DISPLAY_NAME));
String contact_number = cursor.getString(cursor.getColumnIndex(ContactsContract.CommonDataKinds.Phone.NUMBER));
String result = contact_id+"\n"+contact_name+"\n"+contact_number;
contactArray.add(result);
tempId = contact_id;
ArrayAdapter<String> adapter = new ArrayAdapter<>(this, android.R.layout.simple_list_item_1, contactArray);
listView.setAdapter(adapter);
cursor.close();
ZTE Axon 40 Ultra
Seems like a competent well specced device. Never had a ZTE phone myself, but have seen plenty of them and have also seen the ZTE factory in Shenzhen where they're made.
I became a fan because my first smartphone was a ZTE 812 Maven running Android 5.1.
It died after about 10 months, but was under warranty and replaced.
That one is still alive even after I replaced the 'non-replaceable' battery.
My Ol'lady had a ZTE that was running KitKat while the rest of us were using Android 7.
Her ZTE 557VL running Android 7 is just now having battery failure.
If her screen wasn't busted, I would just get a replacement battery for it.
Help Galaxy Tab S7 question (home screen)
The Nova launcher didn't work.
.... Have you tried pressing and holding on an empty bit of home page, or maybe pinching in, and seeing whether any settings options appear?
My experience of Samsung's launchers on my ancient Note 10.1 and my s21 mean I would not put it past them doing something restrictive and inefficient for their own reasons.
Yes, I tried. That doesn't work.
It makes no sense why they would take away valuable "screen real estate". I suppose they hired some idiots away from Apple.
Filter
