PRL's in one zip
00001
01115
01120
01337-mod
11114
11115
22081
31010-mod
31010
52341
60676
60677
60679
60681
61007
61677
Trial and error, worst that can happen is you switch back to the boost one if a sprint one doesn't make a noticeable difference. (menu>settings> about phone> update> update prl)how do you guys figure out what prl to use? i'm in hawaii so i'm guessing i'd need a different one from what u guys are using.
has to be a port below 9 i thoughtJust change the com port of the samsung driver to a single digit that is not in use and you can use the trial version just fine to change the PRL.
Tried CM7 and a few other roms so had to go to boost default PRL before doing so and in the mean time my CDMA trial expired so stuck now on the default boost prl anyone know a way around the trial period without having to spend $100 to buy it.
Ahh so its you who is making this website difficult to get toi have a cracked cdma workshop, if i upload it SOPA will take down this site lol
nah, thats not me haha.
Are there better prl's to use within a certain radius of your location or are they pretty much nationwide? I'm in CT and wonder if anyone else from CT use a certain prl with great results.
So, new optimus just found a way to update your PRL in CM7 using ADB
This is a way around hidden menu because CM7 doesn't have hiddenmenu.apk
Plug your phone in to the computer
to enable DM mode
open a shell (adb shell)
at the # type: echo 1 > /sys/devices/virtual/usb_composite/diag/enable
Your pc will give the unplugged sound and your samsung driver will show up in the COM port in the device manager like so:
Now open CDMA Workshop and choose your PRL as you would normally
When your done, to disable your DM mode
open a shell
at the # type: echo 0 > /sys/devices/virtual/usb_composite/diag/enable
you will here the unplugged sound again, your COM port should dissappear, and ADB will go back to your home folder like so:
then open a shell
#reboot
and you have your new PRL
All thanks go to new optimus for finding this and bringing it to our forums. If this helped you then you should go over to the Hroark's CM7 thread and hit his Thanks button Here
post http://androidforums.com/3853821-post1916.html
ADB just puts your phone into dm mode.. you still have to update the PRL with CDMA wshop..Hope the adb trick for Changing the PRL will work with CTMod as well. As I do not feel like paying at least $100 for CDMA workshop since my trial expired and I have moved and I am getting a very crappy signal here with the boost prl and I can not change it to a sprint one since I know sprint works very well out here but I do not have access to the towers around here
