I feel like an idiot, I can not find the link, my good fellow...![]()
Its in the OP Under DOWNLOAD, Although it says MILESTONE3 NIGHTLY The Date is 52113
Well I heavily used for most part of the night and it's a great improvement.
I had an issue with the return and home button. Most of the time they "stick " making the phone to vibrate uncontrollably for a few seconds.
In my case also the battery seemed to deplete faster than the M3.
But all the apps worked fine.
Some of the heavier RAM users have some lag and are choppy. But that's normal in the phone.
Great work! I'm looking forward to the new builds!!!
Oh! And for the ones who care (guess not may l many) Candy Crush just don't loads LOL.
Thank you so much for all the time and effort you poured into this.
This is because iam in the process of switching out the kernel. so some things. just arent right. if it doesnt improve, i will be going back to the other kernel, and manually patching to .14 instead
I flashed it over last night and got distracted(as usual) and my sister called... twenty minutes into the call I'm like " hey your not on speakerphone and you can hear me!!".... she wasn't as excited as me about that....![]()
I am still having same issue with WiFi. I have only tryed it at home, I'll try it later on a public AP.
Yes. Sadly. I don't know why we have to reboot to enable WiFi. On the other hand. The timing out is dhcp. I've looked into it. But not sure what's going on. I am pretty much doing cm10 by myself at this current point. Until DTM can return. So development is a bit crippled but am hangin in there
I commend you on the job you are doing dude, this rom has come a long way. I wish I were half as bright as you guys working on this, thank you very much.On the wifi, it picks up my network signal at 100%, then when I connect it drops to about 5% and says ignoring networks with weak signals.Yes. Sadly. I don't know why we have to reboot to enable WiFi. On the other hand. The timing out is dhcp. I've looked into it. But not sure what's going on. I am pretty much doing cm10 by myself at this current point. Until DTM can return. So development is a bit crippled but am hangin in there
!!!!! Srry for my bad english im realy makin an effort XDHad a somewhat scary problem when flashing M4 in TRWP 2.5 system completely locked up on boot every time, finally had to hard boot and recover to CWM and reflash M4.
I suspect it's more likely an issue with TWRP then the actual M4 nightly but just wanted to share anyway just in case its relevant.
Keep up the good work![]()
Sir how do you boot into recovery when running this rom?
Was Rick anywhere close to the money?
