Chrisdarasta
Google Market keeps force closing
an off topic comment hroak i love ur uncle muscles picture!!
Great Job!
I don't get it
Try installing Telenav...mine wont lock very well without it. Took more than 10 minutes sometimes. You can find it on the market.FYI hroark, I can't get GPS working with beta 2d. I tried "GPS fix", but it still can't find my location.
How are you formatting? are you partitioning it as well?
I'm not sure if this was posted already or not, but is anyone else having the same issue with the camera button on the side of the phone not working. When I open the camera app and press the button, nothing happens. But I can take the picture tapping on the screen.
Thanks again for all the great work in this beta.
FYI - I saw under the setting that you can use the up/down and or power buttons to take the photo, but not the camera button.
i would format & partition right from CWM recovery on your phone. i tried doing it on the computer and for some reason it had trouble mounting it.I've used the standerd windows formatting, and some formatting software that I don't remember what it is called. And I'm not doing and partitioning. Couldn't get a2sd to work and didn't really need it anyways.
Odin
Depends on which Odin file you use. Check out beginners guide to prevail that will tell you everything you need to know
try from CWM with these settings 0swap / 256 ext and format
I know most of the people are using a2sd here but I use link2sd on an ext4 and its NEVER given me a problem at all and it auto links anything in I install so you set it up once and forget it... I've seen to many problems with a2sd so i wont use it
the fact that you tried two cards means that its either a hardware problem with your phone or its cm7.So I finally got around to test the SD card. I formatted it using CWM and no luck. After I rebooted in it wouldn't recognize it. So I tried booting back into CMW and it won't recognize it there either. Tried different SD card and the same thing happened with that one as well.
Question.. did you ever have problems with the SD mounting before you flashed CM7 ?
If NO you never had problems, I would suggest a reflash. formatting /system and /data in CWM first to make sure you get a clean install. (I had to do this too before everything worked right although I didn't have any prob with my SD)
If it has always acted funny then that would point more towards a hardware problem with your phone.
Question.. What were you running before you flashed CM7 ?
If you were running the gingerbread update you may have to Odin back to EE14 before reflashing cm7.
the only issue i have is that root explorer goes to a black screen says its been granted superuser permissions then after like a minute says it stopped working unexpectedly and force closes should i delete root explorer and re install? an i keep seeing people comment on quadrant scores how do i look at my quadrant score
