Make sure your swype keyboard isn't moved to sd card. If you're using a2sd or s2e. Anything that the system is depended upon should not be moved to sd card or u will find yourself going into setting/ keyboards/ and having to reselect the keyboards that u want to use. I'm still using beta 3.5 with hf2, it has it's issues but I'm content. Try "TouchPal keyboard" and "Slideit Keyboard" both have "swype" slideit has a lot of different skins and some are cool. Hope this helpcant get swype beta to work. it installed but i select it in language and keyboards and when i put select input method it wont show. then i go back to settings and swype is disabled.
i have some scripts so i dont know if thats the reason. maybe some one with out scripts can try it and see if it works
edit: did a reboot and swype appears when i hold down to select input method but i select it and it just goes back to android keyboard
First you do NOT need to go back to stock to change prl. download bloods ctmod and flash it(after making a backup of your current one of course) then use ctmod to open the dialer menu's and then go back to recovery and restore your back up. or flash cm7 back then restore your backup I dont know the best way for that any longer.Does anyone know where I can get the cacherfs.zip? Megaupload has been shut down and I can't find it anywhere else and I want to change my prl.![]()
Second here is that file for when you do need it.
anyone is able to rehost it somewhere else its great with me this is just my home server.
http://localserver.no-ip.biz/Public/cacherfs.zip
momentsdo you use mac addy filtering on your router?Cm7
Beta4b
Hotfix3
Freshly installed
Problem:wifi not working tryed to connect always getting a disconnected
Cm7
Beta4b
Hotfix3
Freshly installed
is wifi dissconnecting when phone goes into sleep mode?
. Don't ask me why it's like that because I dunno , I'm sure Hroark could answer that question or at least give you a better educated guess than I could . Maybe because of me ????? HEH , I doubt it but maybe . LOL . I've followed the same install procedures every time .
Hmmm!
It seems I went from -96dbm on my test with gingerbread to -86dbm with cm7? Maybe its the weather here?
is there any way to tweak the phones responce to the tower signal while on cm7?
How many oggs did you get rid of? I wanted to add and change a few sounds. How would I go about this, sir HROARK?
So i just used my speaker ohone to day to my suprise i couldent here au
nething with it turned up tried messing with setters and did reflash cm again with no fix has anyone had this poblem too. Also my android keyboard runs slow anytime im typing online but no other time any help would be appreciated
The speaker phone works perfectly if you are on the newest hotfix.
Actually, this is one fix for which many of my friends are thankful. The feedback from the older versions drove them to the point of insanity. Although, for some of them, that is not much of a stretch.
The speaker phone is definitely a handy feature that I use a lot. All my friends give the hotfix 5 stars.
I use Swype, but have noticed no problems using it or the stock keyboard. Online or off.
The only thing I have been frustrated with on CM7 is Battery Life. Everybody else seems to be raving about it.
Of course, my main problem is that I never put it down. Screen is always on. I guess I avg about 6 hours when I am doing that.
I got spoiled back with SHABBYMOD. Once New Optimus, found the solution, I was getting at least 2 days. Maybe 18 hours with fairly heavy use.
I know GB runs faster, etc. but I just can't get anything close to that now.
I finally broke down and reinstalled Juice Defender Ultimate. So far the results are dramatically improved.
To soon to really quantify but I will try to see what it will do.
I would prefer a solution without using an optimizer app. But, I bought it back on SHABBYMOD, so I will give it a try.
Things have quieted down in the last few days on new enhancements to play with and I had to do other stuff today and tomorrow too anyway, so it will be a good test of a lightly used phone.
I have tried some of the performance tweaks of CM7, but was not satisfied with the lag I usually got. I might not have tried the right combination.
Maybe I just want my cake and eat it too.
Go into the performance section of the cyanogen settings and set the CPU governor to on demand. By default it is set to performance which leaves the CPU running at its highest frequency at all times
Gonna try the On demand sitting too . I'm going through two batteries a day . Actually probably more than that because I keep it plugged in to the USB some . I sure am glad I bought those extra Batteries and charger from eBay . LOL
