BRAINZ2013
Extreme Android User
You need to reset the device from the setting menu
I didn't think you could be in test mode cause u have to press something to get into the test mode . But u need to factory reset the device to get service restore
:what:I don't know if anybody else has, but lately my lg has been coming on with WiFi and 3G and 4G. But I went into settings under wifi and check that wife I will never sleep, but it still keeps popping up either wifi and 3G together that one or wifi and 4G. Now I've tried everything and I don't know how to stop it. Has anybody else encountered this too?
Here it is try this to restore your lg esteem .
1. Download and extract the doc file it has the lgpnst and the DLL following the directions will put you back in working order the file download is
https://m.app.box.com/view_shared/42670c11cc31d546a6f6
2.Get the driver for the phone and install it http://www.lg.com/us/support/mc-supp...er_1.0_All.exe
Remove your battery and connect your phone via usb (the hard buttons on the bottom of the phone should blink slowly). **Make sure battery is at least 25% charged
Hold down power + vol up.
Phone will come on and read "downloading do not remove cord"or something to that nature. Put battery back in.
If you followed step 2 correctly, LGNPST will now show an unknown device and will be in emergency phone bookmode.
Under the emergency tab it will ask you for 1) a .dll file and 2) a phone book. Click on the folder icon next to .dll file and load the VS910.dll from wherever you have it saved. Click on the folder icon next to phone book. Navigate to the folder where you have saved the correct .tot file. in the "file name"box type *.* and hit enter. If you are in the correct folderyou shouldnowsee the .tot file, click on it then click "save".
Back on the LGNPST screen click on start. It should now say MASTERBIN and a percentage ticking up (if not you have done something wrong).
